Old 09-20-2014, 10:37 AM   #1
Water holding tank
Ok, I left the manuals at the house. This is my first trip that I've needed to use the water holding tank.
I pulled into the campground fill station, and filled the tank. I setup the camper and turned on the water pump. I don't get anything but a bit of air and water. The pump doesn't appear to shut off.
Is there a valve that I need to turn to change from city water to water from the holding tank?
Not a huge deal to be without water, but as I'm in relaxed mode at the campsite, if it is a simple fix, I'd like some running water.
Any help in the absence of my manuals would be appreciated.
Thanks,
Mark
2015 A122S "The next campsite tour of this type of intriguing camper will begin in approximately 15 minutes. We ask that you refrain from any flash photography as it tends to wake the native inhabitants..."
Camped 6 times in 2014, 5 times so for in 2015
underwhirled is offline   Reply With Quote
Old 09-20-2014, 10:55 AM   #2
Thanks,
Mark
Do you have a (W/H) if so it will fill 1st before you get Water (Down Stream)! Youroo!!
Old 09-20-2014, 11:22 AM   #3
It appeared to not want to accept anymore water. Do I just need to give it a period of time and the try filling again. I did look at the tank underneath, and confirmed that I don't see any water in the tank.
Old 09-20-2014, 11:29 AM   #4
How many Gal.is your (FWT) if it is below (6) Gal. you used all of your Capacity to fill your W/H! You need to fill up your FWT agin. Youroo!!
Old 09-20-2014, 11:33 AM   #5
The holding tank is about 20gal.
I'll try filling it again and see if that works. I appreciate your help and quick response!
Have a good weekend!
Old 09-20-2014, 01:59 PM   #6
Depending on how long you let the water run, it could be the water filter housing causing the problem. It will fill up shortly but can cause pump stuttering or air mixing in the water if no filter is installed in the canister. Or low pressure if the filter is in. If you don't plan on using the filter, take the housing out and replace it with a 6 inch long, 1/2 inch pvc nipple.
Other possible causes of pump running with low water pressure is a partially open low point drain, or less likely, a leak in the intake line.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 09-21-2014, 08:48 AM   #7
I found the issue. The tank was actually full, but during the dealer prep when the filled an flushed the tank, they left the valve next to the tank in the wrong direction.
This allowed me to fill the tank, but caused the pump not to be able to get water from the tank to the faucet.
I rotated the valve, and everything worked like a charm. If I'd had the manual with me, I bet I could have easily found this.
LESSON LEARNED - KEEP THE MANUALS IN THE CAMPER. or remember to bring the MacBook with the PDF manuals with you.
Old 09-21-2014, 09:01 AM   #8
Herk7769's Avatar
A loose fitting just prior to the pump will prevent the pump from priming.
The winterization valve may still be in "antifreeze" or "winterize" preventing access to the fresh tank (or not fully switched).
Levelness will prevent the fresh tank from filling completely or completely emptying (depending on levelness when filled and then again when parked).
Photos are examples only and not indicative of your installation.
Name:	Horst Probe Install 019.jpg
ID:	63211   Click image for larger version
Name:	Horst Probe Install 020.jpg
ID:	63212   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 09-21-2014, 09:03 AM   #9
Herk7769's Avatar
Glad you found the problem. Answered your post from an email.
Old 09-21-2014, 08:22 PM   #10
Glad you tracked down the cause. Thanks for posting your solution.
Tom
2012 Rockwood A122S
tank, water
