Old 04-27-2015, 06:35 AM   #1
Water not working properly
Our water system is working fine when hooked up to a water source but when trying to draw water from the tank it sputters and spits and the water pump does not shut off. Any ideas? Last year it was working fine.
maminkagirl is offline   Reply With Quote
Old 04-27-2015, 06:41 AM   #2
Make sure if it has an antifreeze suction line that the valve is closed and another member found that the screw on screen on the pump was loose and when tightened the pump worked great,
Old 04-27-2015, 06:41 AM   #3
TURBS's Avatar
Check the tightness of the little water strainer.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-27-2015, 06:45 AM   #4
Herk7769's Avatar
You are sucking air in the intake line to the pump:
1) Make SURE the fresh tank is full. Due to the location and levelness of the tank, you may be indicating 1/3 full but the suction line may not be completely submerged. (see photo) In the photo, due to the "levelness" the tank is "full" but only indicates 2/3 full. The reverse is true if the tank is not level in the other direction. It would suck air and still indicate it has water in it.
2) Make sure connections on the suction side are tight.
3) Make sure the antifreeze/water selection valve is all the way to the water side.
Name:	Horst Probe Install 019.jpg
HAM CALLSIGN - KC3FFW
Old 04-27-2015, 06:52 AM   #5
Ford Idaho's Avatar
Never mind I see it is covered above.
Old 04-27-2015, 07:04 AM   #6
Thank you! Any idea where the the antifreeze suction valve is located? I think that might be the culprit since the dealer did not dewinterize the unit as I requested.
Old 04-27-2015, 07:07 AM   #7
Herk7769's Avatar
If it was in freezing weather and not winterized, the strainer bowl could be cracked and leaking or the pump itself may be leaking.
Depending on where your pump is located, it should be VERY close to it so you can access the antifreeze jug.
Old 04-27-2015, 08:03 AM   #8
AFAIK, A-Frames do not come with a winterizing valve on the water tank draw line. At least mine didn't. As others have said, make sure the tank is full and check the connections on the draw line. And look for wet spots and drips.
The following may not be your problem, but it is similar and experienced by many A-frame owners.
Sputtering and the pump running on for a short while after the faucet is closed can be caused by the water filter housing. Since the actual filter causes a notable pressure drop the dealer may not have installed it in the housing. The solution to this is to remove the housing from the water path by unscrewing the pipes installing a 3" of 4" MPT nipple in the filters place. If the filter is in place and is clogged, then look at changing it or removing the housing, as you prefer.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-27-2015, 08:12 AM   #9
Flybob's Avatar
If the dealer winterized and the unit did not come with a winterizing valve, the dealer probably disconnected the inlet side of the pump and connected the antifreeze feed. They may not have tightened up that fitting when they put it back on. It will be on the input side of the water pump.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-27-2015, 08:48 AM   #10
There is a valve at the bottom of the tank under the trailer near the drain that sucks in air if open. Make sure it is closed.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
water
