Old 08-09-2015, 08:00 AM   #1
kdot's Avatar
Watts Up?
Having just purchased a Honda 2000 generator, I am interested in finding out just how much current is drawn by appliances in my A122S, so that I know how many things I can have turned on at the same time and not go over the 13.? watt capacity of the gennie. Most appliances supply volts and amps figures only. I know there's a formula for determining watts by multiplying volts X amps, but multiplying any figure X 110 volts doesn't seem to work. Anyone know what I'm doing wrong with this?
Kdot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 08-09-2015, 08:12 AM   #2
Phat Phrog Stunt Crew
elind's Avatar
Kdot
Volts X Amps = Watts. So 120v X 13amps = 1560 Watts. That equals about the running max of the Honda 2000 generator.
Peak starting watts is 2000 watts.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-09-2015, 08:14 AM   #3
wmtire's Avatar
Kdot
The tag on the appliance usually has the voltage number for it. You may see 110, 115, or most usually now, 120 volts.
You can take:
Watts = volts (120) X amps
Here is an example using the tag for the electric heating element on a Suburban water heater. As you can see it is rated for 120 volts.
1440 watts = 120 volts X 12 amps
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-09-2015, 08:17 AM   #4
And, those genny numbers quoted are often the peak output. I have the same genset and it will reliably put out about 1600w.
And, just for my anal need to be thorough, electrical motors need more power to start up; often called startup cost. Fridges and A/C units are notoriously high on startup cost. For less efficient models, double the amperage for about 1-2 seconds.
Sent from my iPad using Tapatalk
pugsrcool is offline   Reply With Quote
Old 08-09-2015, 08:55 AM   #5
Another way is to use a Kill-o-watt meter between your power source and the appliance. It will display volts, watts, etc to that appliance. More reliable than using a label.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-09-2015, 09:31 AM   #6
Flybob's Avatar
X2 Kilawatt. I keep mine in the RV
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-09-2015, 04:34 PM   #7
kdot's Avatar
Watt's Up?
Thanks everyone; I think I'm beginning to get it.
Kdot
2017 RPod179
2016 Honda Pilot
