Old 04-25-2012, 11:39 AM   #1
Question Weight Distribution Hitch
Does anyone here have a weight Distribution Hitch on their pop-up or A-frame? I have a Montana Van to pull my 228D Pop-up. The Van has no Tow Package, so to make up for the lack of the tow package's auto-leveling airbag suspension I decided to put on a small weight distribution hitch.
I haven't gotten the hitch installed and adjusted yet... but I was just wondering...
My driveway is inclined.... and my street has a small crown to it. Is this going to put too much pressure on the ball/spring bars as I pull out of the driveway?
Comments/Thoughts?
lemoj1 is offline   Reply With Quote
Old 04-25-2012, 12:12 PM   #2
No expert here but I'm learning. Your van was likely designed to have tongue weight on the hitch. It may or may not be designed to twist the hitch forward like a WD hitch does. Most modern minivans do not have frames, but only reinforced sheet metal to bolt the hitch to. It is very good as intended, but some manufacturers don't like WD hitches. I put air bags on my jeep. Less than $100...but, WD hitch would have probably been better in my application. Just food for thought.
CCrane2299 is offline   Reply With Quote
Old 04-25-2012, 12:32 PM   #3
Jeep4Two's Avatar
Check your owners manual regarding use of a WDH. I may not be allowed on a uniforms vehicle and is normally not recommended.
On my Jeep I use a WDH setup, see my signature for details.
If your Montana is spaced to tow the total weight and handle the 300 lb plus tongue weight you should be ok. I would suggest an auxiliary transmission cooler to prevent overheating of your transmission. Too much heat will kill the trans.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 04-25-2012, 01:01 PM   #4
Triguy's Avatar
I agree with those guys above. You should check your manual.
Also, what size receiver is on the van now? I see a lot of class II (1 1/4") receivers on vans and I don't know of a WDH for class II. It would need to be class III.
Certainly install an aux transmission cooler and a brake controller.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-25-2012, 01:04 PM   #5
Jeep4Two's Avatar
having access to a real computer (was on my iPhone earlier) I can see that the 2009 Montana V6 with 3.29 axle ratio has a maximum trailer tow of 3500 lbs (and 8500 lbs GCWR) WITH the V92 Towing Package (or Heavy Duty Cooling). WITHOUT the V92 y ou are limited to 2000 lbs (and 7000 lbs GCWR).
I would suggest looking into the heavy duty towing / cooling packages and seeing what you will need to do to make sure you update the necessary cooling (transmission cooler at a minimum) otherwise you will face premature transmission failure. I'm not sure what else is included in that package other than the cooler (maybe larger cooling capacity for radiator). I would guess the wiring harness, hitch would be part of that package too.
There is no mention in the 2009 Montana V6 owners manual of Weight Distribution Hitches so I would take that to mean you CANNOT use a WDH setup on your van. I rarely suggest checking with the stealership, but that might be a good idea.
Jeep4Two
Old 04-25-2012, 03:22 PM   #6
I have put in a Tranny cooler, Brake Controller, and Class III hitch from Hidden Hitch. The Hitch is a custom fit for my van and the Label on it says it can be used with weight distribution systems. I would think that the label wouldn't be there if you couldn't use it for my van.... but I'll check the manual tonight.
I have checked with 3 dealers.... only one ever got back to me simply saying that the Tow package included (not limited to) Hitch, Wiring, a high output alternator, air bag suspension with associated compressor/computer/ and sensors for load leveling, Larger Rad and Tranny cooler, etc, etc, etc. And it would cost more than the van was worth to install the "Factory Tow Package"
I'm not going into the mountains with it, and not going long distances. I live in the relatively flat Canadian Prairies and only expect to be going to the local provincial parks and back.
I believe that I am within the limitations of the van with the modifications that I have made... but am still learning as well.
Old 04-25-2012, 05:42 PM   #7
Jeep4Two's Avatar
Hopefully someone with more knowledge with unibody vehicles and WDH will chime in. My knowledge is a little limited there.
However I would not trust the label for the 3rd party branded hitch to mean that WDH is safe for your unibody van. I would personally want a more definitive answer to that question. That's just me however.
Have you measured the amount of sag in rear and lift in front when hitched? If you have less than an inch of rear dag and less than a 1/2 inch of lift in the front then I'd say there is no need for WDH (again, my opinion).
Jeep4Two
Old 04-25-2012, 05:51 PM   #8
There are a lot of minivans running with wdh. The rear suspension is soft so you need it if you have much weight on the hitch. I would be worried about the pop up. Quit a few of them do not allow weight distribution hitches because the frame is not strong enough.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-25-2012, 06:09 PM   #9
Jeep4Two's Avatar
I think the AFrames are fine with WDH. They have a pretty heavy frame. I've not seen any issues with my A126, with about 900-1000 mes of towing.
Jeep4Two
Old 04-25-2012, 06:11 PM   #10
Jeep4Two's Avatar
Regarding WDH and the AFrames: I only use a 600 lb WDH setup, and use the next to last link and a little head angle. I've not put it on the scales to get a real number on how much weight distribution that creates but it's not much compared to heavier WDH setups
Jeep4Two
228d, incline, weight distribution hitch
