06-24-2016, 09:23 AM
What are these water tubes for?
I filled our 192HW water tank last night. I noticed this morning that there's been a constant, slow drip from one of two little tubes underneath the camper, near the fridge and hot water heater. (fridge was turned on last night but not water heater)
I haven't seen this happen before, where might the water be dripping from and why?
06-24-2016, 09:30 AM
Those are low point drains, to drain the system for winterizing. Sounds like the cap is just a little loose. Easy solution is to reach in, and tighten by hand.
2015 Freedom Express 246 RKS (Sold 2021)
2021 Grand Design Reflection 150 295RL
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2021: Still Not Enough
06-24-2016, 09:31 AM
Where is the cap?
06-24-2016, 09:46 AM
Condensation from fridge?
FW tank overflow tube, it will not have a cap the other one if capped might be FW tank drain.
06-24-2016, 09:48 AM
Both lines should have a plug in them . One line should be red and one blue. . Tighten the plug just enough to stop leak. They are most likely nylon plugs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-24-2016, 09:53 AM
fridge condensation drain - if dripping its doing its job
low point drains or fresh water tank drain - if dripping tighten the cap
06-24-2016, 09:58 AM
Where is the cap?
At the end of the line. You mentioned there were 2...these are drains and as Bob mentioned, there are normally red (hot water) and blue (cold water).
Ford Idaho asked if condensation line from the refrigerator. That line, by the way, should never be capped.
06-24-2016, 10:09 AM
Correct, the tube I was alluding to if for the FW tank not the fridge drain.
06-24-2016, 10:21 AM
Where is the cap?
My low point drains pull up and push down to open and close. There is no cap to tighten. Yours might be different. not sure what model year yours is or if there was a change in drain styles on newer models.
2012 Rockwood a124
06-24-2016, 10:28 AM
Jodilc,
Seems we are all just guessing at which line is dripping. (as there are multiple lines that protrude underneath)
A photo might help or tracing the line to where the source is could get you better answers.
06-24-2016, 01:12 PM
I am fairly new to RVing myself and sometimes I find the discussions on here very confusing. Some are saying it's the water tank overflow lines and others the fridge condensation line so even I'm not sure what the correct answer is. I say that with respect as people are just trying to be helpful but many topics in this forum have multiple answers and I'm never quite sure what the correct answer is in many cases.
06-24-2016, 01:30 PM
Hi,
This is the exact reason we ask for pictures. If the OP post a picture of the tube (s) in question, we can give an exact answer. Welcome to the forums!
2015 F-250 FX4
06-24-2016, 02:19 PM
The dripping tubes you are describing are the low point drains. They are actuated by "T" handles under the sink next to the water pump on low wall campers. Not sure just where they are on yours, but the handles will be inside a cabinet right above where the tubes protrude. One is for the hot water side and the other for cold. Pull up on them and push down hard to seal them. They may or may not always seal properly. Mine have proven to be difficult to operate.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
06-24-2016, 02:22 PM
There are always many answers in this sub forum from people that don't have A Frames or pop ups (which are largely the same from the walls down). Their campers can be substantially different from ours and the answers can be discounted when it comes to these kind of unit specific questions. To help clarify the weight to put on answers, look at the sig line to see if they actually have an A Frame.
Tom
2012 Rockwood A122S
06-24-2016, 03:04 PM
I figured it out. Got home early from work, looked at the red and blue tubes inside the dinette seat, and saw the valve on the blue tube was sitting a bit higher than the other. I pushed it down and it snapped into place. Why it popped up is a mystery, but the dripping has stopped. Thanks everyone for your help!
06-24-2016, 03:53 PM
Thanks for coming back and letting everyone know what it was. It helps us improve our suggestions in the future. And it helps us learn about other types of RV's than what we have.
Gotta go campin!
06-24-2016, 08:26 PM
On our older Shamrock (2002) there is a straight valve on the red drain and a "T" valve on the cold , both under the bathroom sink. The "T" style has the additional line running to the toilet.
06-25-2016, 05:49 AM
Keep an eye out for this.
My cautionary tale is that when one of mine worked loose, like yours did, and I left the water pump turned on. It ran the freshwater tank dry over a few days of being parked at home so the pump was just churning away very quietly. I didn't hear the pump spinning from the outside. The next trip the pump was spinning but not pumping and had to be replaced. The solution is to double check that the pump is turned off.
I often don't hook up to city water at parks, because I use so little water and often fold up early Sunday morning to get on to the planned hike for the day. So one less thing to do in the morning is better for me. And Houston tap water taste better than local brew served at most state parks.
Tom
2012 Rockwood A122S
06-25-2016, 06:06 AM
Just throwing this out there, red and blue low point drains should NOT be confused with two blue lines that are overflow for fresh water tank.... In addition to that there is a third blue line with a valve that drains fresh water tank.
06-25-2016, 07:43 AM
On our 2013 Sunseeker the blue line has no cap,,, because there is a valve above to drain FW tank,,, Red line is capped,,, when I first saw that,,, I ran to the RV store and bought a spare cap,,, not knowing what could happen if we lost that cap ???
