09-21-2016, 08:46 PM
What Ball For A213HW
Thanks, in part, to what I learned on this Board I have just closed on a A213HW. Walk through scheduled for Friday!
What kind of ball should I be purchasing for this trailer? I will be pulling it with a Jeep Grand Cherokee with the hitch package.
09-21-2016, 08:55 PM
You shoud get a weight distributing hitch with sway control. It will make towing much easier. There are several brands available. I went with the equal-i-zer brand. To find WDHs go to etrailer.com and search for weight distribution hitch.
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
09-22-2016, 02:30 AM
You will need a 2" ball for the A213HW. It is also very important that you have the correct drop on the hitch itself. The best thing to do is back your TV up to the trailer during the PDI a new have the rep determine what the correct hitch drop is.
09-22-2016, 06:01 AM
DW's 401(k) Plan
A WDH for a unit with a GVWR of less than 3300#? It hardly hits the prerequisite of needing brakes. The unit itself is only a couple hundred pounds over a ton. Methinks a WDH is overkill. Maybe an E2 if you want to go that route, but a full blown 4pt Equalizer is way too much IMHO.
But to answer the OP's question, a 2" ball is required. And as Brimare57 states, the drop of the draw bar is very important.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
09-22-2016, 06:56 AM
It's not the vehicle weight it's the heavy tongue weight of AFrames with front storage trunks vs the TV characteristics. If the Grand Cherokee has off road suspension, then I would think the WDH would be a good idea to eliminate the rear end sag. If it has the harder sport suspension, maybe not.
Personally, I'd wait and see how it looked, and weigh it after hitching. And not be concerned about sway control as these campers tow wonderfully.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
09-22-2016, 08:39 AM
I just weighed my 213s tongue weight for the 1st time. With the storage locker pretty much empty, the hot water tank full and the potable water tank about half, it came in at about 390 lbs.
I have a full size chevy ext cab and as you might expect, there is 0 sway.
09-22-2016, 08:46 AM
The op asked for size of ball which given the weight of the unit it requires a 2" ball as others have said. I also agree that a WDH is overkill and to first try the setup without, but with proper drop also as others have said.
Retired Navy
2016 Flagstaff 26 FKWS
09-22-2016, 02:32 PM
Birch Bay, WA
I'm thinking of ordering a A213HW but will need to set up my truck before I leave to pick it up. I have a Chevy pickup and several hitches for it, but it would be very helpful if I knew the best height for the hitch. I would really appreciate it if someone with a A213HW or T21TBHW could measure the height to the top of the ball when the unit is level.
09-22-2016, 03:08 PM
Our 213 is 16.5" off the ground when level.
09-23-2016, 12:14 PM
Birch Bay, WA
Wow, That's quite a bit lower than I expected. Is that to the TOP of the ball? You seem to have a Chevy 4x4 pickup too, so you must have quite a drop on your hitch. Can you tell me how far of a drop you are using?
09-23-2016, 05:13 PM
Not to the top of the ball. I am not an expert and refer to this site:
Choosing the Correct Ball Mount | etrailer.com
My truck does not have the z71 off road package, but does have the trailering package (thus a lower hitch height). Using the criteria in the above site, my hitch height (truck) is 17.5" and coupler height (camper) is 16.5"
