Old 11-27-2013, 07:06 AM   #21
Herk7769's Avatar
Originally Posted by Canyonlands View Post
BTW, that same chart shows you why the 6V is favored.
1 27M is 180 min RC at 25A and 5.7 AH at 15A.
1 6V is 474 min RC at 25A and 14 AH at 15A.
In this case from a longevity of use standpoint, the 6V outshines even two G27s.
Yes, but you STILL need 2 batteries.
Remember AH does not double with two 6volt batteries in series; just the voltage. AH does double with 2 - 12 volt batteries in parallel.
So 2 - 6V batteries above = 12 volts at 474RC minutes (197AH at 25A)
or 2 - 12V batteries above = 12 Volts at 360RC minutes (150 AH at 25A)
Check the difference in weight and cost of the bank as well.
The attachment shows how to convert RC to AH
HAM CALLSIGN - KC3FFW
Old 11-27-2013, 07:21 AM   #22
1A Camper's Avatar
Well is your head spinning yet.
I think you would be happy with either 6V or 12V.
As for mounting my dealer made a frame that sits above the old frame so the battery can still set long ways, and the Propane hose goes between the battery, I also found with the frame raised that the hose would go below the new frame.
http://www.forestriverforums.com/Pho...0ToxFbAxNk.jpg
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 11-27-2013, 07:37 AM   #23
Herk7769's Avatar
Also the "M" stands for "Marine" which is a dual purpose battery and not a true deep cycle like the 6 volt you stated.
To get a true comparison a deep cycle 12 volt battery like a http://www.batteriesinaflash.com/dee...-for-marine-rv should be used.
2 of these would give you a true 200AH comparison.
Old 11-27-2013, 08:28 AM   #24
National Park
Great points and info everyone!
Great information as always herk7769.
1A Camper: : ) No, my head isn't spinning just yet. I'm pretty well read on this and went through the other discussions on portable heaters, small gens, Trojan batteries, 6V vs. 12V, etc…
We always planned on setting up a dual battery system and adding a solar charger so that's what we'll achieve, see if it falls short for our needs and adjust if necessary.
I agree, I bet we'll be fine with either 6V or dual 12V but that's where I see the gray area in this decision. I've decided on 12V for a couple of reasons I alluded to and now it's just deciding which ones. If I can find a couple of Trojan 27TMHs locally then it will be done.
Ron and Kelly
2014 Rockwood A112TH
2004 Toyota 4Runner V8
Always Exploring
Canyonlands is offline   Reply With Quote
Old 11-27-2013, 08:42 AM   #25
Herk7769's Avatar
Not sure how much vertical space you have above your battery mount; but Trojan makes some "tall" batteries that a pair of may fit in your existing mount.
http://www.batteriesinaflash.com/spe...tion_specs.pdf
Like this one.
http://www.batteriesinaflash.com/dee...-cycle-battery
Old 11-27-2013, 09:06 AM   #26
National Park
In reply to herk7769
Outside of the box thinking but also outside of my weight and cost limitations. That's a 100 pound battery. Take a look at the numbers on the 100 pound 6V offerings from Trojan to really see some impressive comparative data.
http://www.trojanbattery.com/pdf/TRJ...dSpecGuide.pdf
My current box and tray is a single group 24 form factor. The only 12V Trojan offers that will fit are those in that 24 form, which the next best thing to a single group 27 Trojan would be this one: http://www.batteriesinaflash.com/dee...-cycle-battery
I bet I'd be fine with two of those as well.
Ron and Kelly
Always Exploring
Old 11-27-2013, 11:38 AM   #27
National Park
I don't think I've found 120 pounds of battery to rival two sealed Trojan SCS200s.
Specs for one SCS200:
Weight (lbs.) 60
5 Hour Rate Ah 95
20 Hour Rate Ah 115
Reserve Capacity @ 25 Amps 200
Reserve Capacity @ 75 Amps 52
Sadly, I haven't been able to find anything like it locally but can have them brought in by the Trojan dealer. Two of those in parallel is what I'm thinking for the near future unless something more compelling surfaces.
Off to buy a Mr Buddy heater and we'll be relying on this single Interstate HD-24DP for the 4 day weekend.
Ron and Kelly
Always Exploring
battery
