Old 04-17-2015, 10:13 PM   #1
What's This?
What's the purpose of the white lever on the upper door? What type of tool is needed to remove it as it isn't slotted for common screwdriver or a Phillips screwdriver?
dmtex is offline   Reply With Quote
Old 04-17-2015, 10:15 PM   #2
toslow's Avatar
is it a lock of some type?
haven a blast
toslow is offline   Reply With Quote
Old 04-17-2015, 10:22 PM   #3
Is that the only one? I do not know about your camper but it appears to be a screen lock. As far as removal there are special bits to remove them. Sears.com
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 04-17-2015, 10:57 PM   #4
handbuilder's Avatar
This locks the top door to the door frame when you fold it down. It prevents it from bouncing around as you travel down the road.
You do not want to remove it. It's a good habit to make securing the top door, part of your "take down" routine.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-18-2015, 12:51 AM   #5
Ok, thanks
Old 04-18-2015, 04:31 AM   #6
http://www.google.com/url?sa=t&rct=j...YYihMFbp-mEwjQ This is to answer the Q about the (Bit/Tool). But correct answer is a Lock and Don't remove! Youroo!!
youroo is online now   Reply With Quote
Old 04-18-2015, 09:18 AM   #7
Dsfast's Avatar
The reason for this lever is to hold the door in place when the trailer is down and you are traveling
Dsfast is offline   Reply With Quote
Old 04-18-2015, 02:45 PM   #8
yes it is a latch to hold upper door section down/dealer did not know use also/i95 pot holes did the job on my inside section be fore I found out/I laid tow over door section also/dealer put small foam round bumpers over scatches/ha////////
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
ridgeline1 is offline   Reply With Quote
Old 04-18-2015, 06:24 PM   #9
dmtex
