Old 10-06-2014, 05:57 PM   #1
Why does the CoolCat stop making heat at 40 degrees?
When it happened I switched over to the propane furnace, as instructed in the owner's manual.
All the same, I am wondering why 40 degrees, +/- 2 degrees, is the bottom limit?
mickrock is offline   Reply With Quote
Old 10-06-2014, 06:04 PM   #2
B and B's Avatar
The Air to Air heat exchanger is not that efficient. The coils are not big enough to extract much heat. You could use a fireplace or portable ceramic heater to save on propane. I had a Carrier heat pump that used more electricity below 0 than using electric heat.
B and B
Old 10-06-2014, 08:04 PM   #3
All heat pumps will frost over the outside coil when the outside temperature approaches freezing. They have to run in defrost mode part of the time to get rid of the ice. We have a Dometic Brisk Air 15,000 btu/hr heat pump/ air conditioner on our 2011 Class C Sunseeker.
The instructions for the thermostat says that below 40 F outside temperature it will periodically run in defrost mode, during which the compressor runs to heat the outside coil, but the fan doesn't run because it would be blowing cold air. Below 30 F the thermostat will shut off the heat pump and run the furnace, even though heat pump is selected. Newer coaches use a different thermostat, from our 2011 year model, but they probably work the same way.
Maybe the instructions for your thermostat explains this sequence of operation for your unit. I had to get our instruction manual on-line.
Old 10-06-2014, 08:20 PM   #4
All heat pumps suffer from low efficiency at temps near freezing and stop working at some point. There is just a limit to when heat that can efficiently be drawn from cold air. Much like an air conditioner would stop cooling if the outside temps were near the temperature of the compressed refrigerant. The home heat pump we once owned had a electric coil backup. We AFrame owners have gas furnaces.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
cat
