Old 09-13-2012, 09:38 PM   #1
Will a Jeep Wrangler pull it.
Just wondering if anyone has pulled a Rockwood Aframe with a jeep wrangler?
If so, does it work? The book says it is rated at 1,000 or 25 square feet of frontal space.
Laura June is offline   Reply With Quote
Old 09-13-2012, 09:54 PM   #2
Yes.
CCrane2299 is offline   Reply With Quote
Old 09-13-2012, 09:55 PM   #3
CampingQueen
You need to know the towing capability/weight of the Wrangler and also the weight (empty/dry and total max load) of the camper you are considering.
What I can find says the standard Wrangler only has a towing capability *MAX* of 2000 lbs. That apparently depends on the year & model you have and if you have the towing package. Explore Jeep Capabilities | Towing Reference Guide | Jeep
**EDIT... I did notice a tab where there are some Wrangler models (on the "Unlimited" tab in the above link, that have tow capacity up to 3,500. If you have one of those, then an A-Frame would be within the capacity. ***
The smallest A-frame that I can find on the Forest River website is model A 102. It has dry weight of 1,666 lbs, max weight fully loaded of 2,415 lbs.
Even empty, and assuming your jeep has the 2,000 lb towing capability, that would be maxing out your vehicle. The towing capability is calculated assuming NO cargo in the jeep and only 1 person of 150 lbs. Add gear and a 2nd person and a full tank of gas, and you are over the 2,000 lb towing limit.
If you have the jeep model with only 1,000 lb towing capability, then I personally wouldn't use it to to any travel trailer. I don't know of any traditional TT that is less than 1000 lb. But, let's see what other say...
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 09-13-2012, 09:57 PM   #4
Correction...no. I see you have a 1000 pound limit. You must have a 4 cyl jeep. If so, no it will not pull it.
Old 09-13-2012, 11:21 PM   #5
bikendan's Avatar
with a 1000lbs. tow capacity, you'll have a hard time finding even a popup to pull with that low of a number.
you might want to look at alternative types of campers, like super-lite tent campers.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-14-2012, 07:12 AM   #6
Kaytee1206's Avatar
We pulled a quicksilver pop up by livin lite with my 4 cylinder wrangler
2013 Rockwood Roo 25RS
Kaytee1206 is offline   Reply With Quote
Old 09-14-2012, 07:26 AM   #7
Triguy's Avatar
I'd have to agree. The Wrangler is not known as a good tow vehicle. Fun capable off-road climber, but not for towing a camper of that size. I believe the hitch is a class 2 and it sounds like yours did not come with the towing package, which is why it's 1,000lbs max.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-14-2012, 09:33 AM   #8
Have a jeep. It's rated to tow more than yours, but even I wouldn't use it to tow that trailer.
Kathyrarnold is offline   Reply With Quote
Old 09-14-2012, 11:35 AM   #9
Jeep4Two's Avatar
You need to check on what your Jeep is rated to tow. Here's my setup:
2011 Jeep Wrangler 2-door (short wheelbase), Automatic with the 3.8L V6. That setup will include the 3.73 rear axle ratio and is rated to tow 2000lbs with 200lbs tongue weight. The 4-door, same engine and transmission, is rated for 3500lbs and 350lbs tongue weight.
Jeeps with the manual transmission can have one of three rear axle ratios, 3.21, 3.73 or 4.10. The 3.21 axle ratio is rated for only 1000lbs of towing.
If you have the tow package and a manual transmission, you will have the 3.73 axle (or the 4.10 on a Rubicon, or a 4.10 if it was added as an option).
The key is axle ratio, and length of the wheelbase.
My 2011 A126 A-Frame has a dry weight of 1924lbs and a tongue weight of 270lbs or so.
The hitch that is included in the tow package is a 2" receiver, listed as a class II hitch. I'm not sure why it's listed as a class II and is a 2" receiver, but it is.
Bottom line: Check your setup, and if you have a 3.8L V6 with a 3.73 or higher axle ratio you can tow 2000lbs with the 2 door, or 3500lbs with the 4 door. If you have a Jeep that is older than a 2007, then you'll have to look at the older model specs.
My setup is actually towing slightly more than rated when loaded. The camper dry weight of 1924lbs is without propane and battery, so add that in and I'm right at 2000lbs. Add camping gear and I'm in the 2200-2400 range.
To make my setup safe I added a Weight Distribution Hitch (WDH) and redistribute weight to the front axle (the short wheelbase doesn't like the heavier tongue weight, so the WDH balanced things out). The Jeep tows great (or as great as an underpowered 3.8L v6 can tow). It's not a rocket, but it does fine.
I also added an auxiliary transmission cooler to help keep the transmission cool. The Automatic tranny on the Jeep is known to run hot, so I wasn't comfortable towing without an aux cooler.
See my signature for details on my setup including part numbers for the WDH, Shank and Transmission Cooler.
No need for an aux tranny cooler if you have the manual transmission and a 3.73 axle or higher. No need for WDH if you have the 4-door. Just add the 7-way wiring harness, a brake controller and choose a camper that keeps you in the right tongue weight and total weight range.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 09-14-2012, 11:59 AM   #10
Jeep4Two's Avatar
Here's a pic all setup in tow mode after returning from a short trip. I have a little over 1000 miles towing this setup so far with no problems. It's all about making sure your vehicle is properly equipped and setup correctly:
Jeep4Two
