Old 10-26-2011, 11:29 AM   #1
Mostly Harmless
thehamguy1's Avatar
Window caulk shrinkage, A-frame camper
One of the things I looked really closely at when we took delivery of our camper last February was the caulking around windows and doors, especially the large bubble window. It was very well done, and I've had no problems with leaks there. The mechanic who did the walk-through for us stressed that we should inspect all caulking at least twice a year. It seemed excessive but now I see why.
Over the months, I suppose the bubble window has expanded and contracted hundreds of times. Now the caulking has separated from the edge of the window most of the way around. Not a wide separation but enough to make a tiny water channel. Thankfully I've had no leaks so far. Looks like I'll have to remove and replace the caulk before storing the unit this Fall, though. I haven't found any other caulk failures on the camper.
Any advice from folks more experienced at recaulking than I? What's a good caulk to use? Any tricks to getting a good bond between the plastic window and the caulk? I'm sure there's dirt and dust in the joint area now. I read somewhere that a thorough cleaning with alcohol should be done, maybe that and an old toothbrush.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 10-27-2011, 07:18 AM   #2
I would use ProFlexRV. I have used this product before on my canvas popups roof and found this to be an extremely good product.
However, due to the fact that its in your roof, and the roof is under warrenty for 5 years, i would take it back to the dealer and have this done by them. Perhaps the window was not put in the 3m stuff that was used at the beginning of the manufacture. As the seal on my roof at the window is still very rubbery ... I would think that this is a sign of something wrong .. and should be atleast looked at by the retailer/service department.
My unit has been camped in for 50 nights this year, and with all the towing and setups, i have no issues with the back window.
Hope this helps .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-27-2011, 09:07 AM   #3
Mostly Harmless
thehamguy1's Avatar
Thanks for the advice, D-mo. I guess I should give my dealer a call.
2011 Rockwood A128
60W solar system
Old 10-28-2011, 04:37 PM   #4
The only caulk seperation I have had so far is along the 90 deg angle iron that goes across the bottom rear of the trailer. I stuck some tooth picks along the seam to make a gap, filled it with white caulk then removed the toothpicks. Cleaned up with water. Looks good, but I'll keep an eye on it.
toleworks is offline   Reply With Quote
Old 10-28-2011, 07:22 PM   #5
Mostly Harmless
thehamguy1's Avatar
Was there any dirt or dust in the gap? There's some in mine. Did you clean the area before putting the new caulk in, or after? Precleaning is the part of the job I hope is done well, otherwise I'm not sure the replacement stuff will stick.
2011 Rockwood A128
60W solar system
Old 10-29-2011, 10:00 AM   #6
I have supplied a link to what my dealer used on my bubble window. He stated this is what FR originally used before going to regular caulking. He also said they have gone back to this tape.
The tape is available from several places online. It can be installed without having to go back to the dealer.
I avoid anyone working on my trailer other than myself.
3M
Installation Videos:
3m extreme sealing tape - Yahoo! Video Search
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 10-29-2011, 10:14 AM   #7
Mostly Harmless
thehamguy1's Avatar
That looks like a great item to have on hand. What width of tape did they use on your window? The videos mentioned 2" tape, which at one vendor (Hisco) runs $56.78 a roll, plus shipping. Worth it if you never have a leak, though. How does it look as installed on your unit?
2011 Rockwood A128
60W solar system
Old 10-29-2011, 10:23 AM   #8
Without going out and measuring, I believe it is 2.5".
The next time I'm outside I'll get the actual measurement.
Old 10-29-2011, 09:00 PM   #9
Jeep4Two's Avatar
Love to see some pics too!
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-01-2011, 05:46 PM   #10
Sorry for the delay. The tape is 2.5" in width.
Photos as requested:
ID:	8923   Click image for larger version
a-frame
