Old 07-02-2014, 07:47 PM   #1
Jsusluvsyou's Avatar
Window leak
We have a122bh with a big window leak above bed. Taking it to lazy days in the morning. I had it in the drive way with front higher to help prevent a leak. Also going to have them check gas water heater it alarmed last time out. Haven't used it much. Nervous about the gas and water leaks
Jsusluvsyou is offline   Reply With Quote
Old 07-02-2014, 07:50 PM   #2
It is a 2014 and we have had it a bit over a year so it's out of warranty. Did buy the extended warranty from Forest River, not sure if these issues will be covered, wondering what the cost to fix these will be. Heard 3M tape fixes window leak but anyone know what it costs?
Old 07-02-2014, 09:49 PM   #3
You'll need two rolls. My A122 had the 75mm from the factory. You might be able to get away using the 50mm.
3M PREFERRED CONVERTER Sealing Tape,Ionomer,White,50mm x 5Yd - Film Tape - 15D133|4412N - Grainger Industrial Supply
3M PREFERRED CONVERTER Sealing Tape,Ionomer,White,75mm x 5Yd - Film Tape - 15D135|4412N - Grainger Industrial Supply
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 07-03-2014, 03:17 PM   #4
Mostly Harmless
thehamguy1's Avatar
Be sure to read 3M's directions for applying the tape. I found them on their website a year or so ago. There are several steps, one of which requires something like a brayer or wallpaper seam roller to get good adhesion. You also want to apply the strips in the right order so the overlaps channel rain the right way. I believe that means installing the strip along the bottom first, then the two sides so they overlap the ends of the bottom one, and finally the top strip so it overlaps the upper ends of the side strips. Someone who has this installed please jump in and correct me if I have that wrong (I have the tape, I just haven't installed it yet).
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 07-03-2014, 04:34 PM   #5
I cannot remember how the window was taped, but, I followed your logic when I applied 2" tape around the roof vent.
Dave
Old 07-03-2014, 06:01 PM   #6
Hamguy has it right .. mine has had this done twice .. to correct the original failure .. and the 2nd time .. to correct the problem that i had with a tree in my front yard ...
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 07-04-2014, 01:13 PM   #7
Found 2 small window cracks, warranty will cover it, no news about gas alarm sounding, they did say calking needed replaced, never did that, any tips? Wonder what Lazy Days charges?
Old 07-07-2014, 06:39 AM   #8
Cracks are what concern me the most. Acrylic is not a really durable material for constant exposure to sunlight.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-23-2014, 04:01 PM   #9
So I have a small crack in the corner of a window & it is causing a leak when the rain hits it just right. Problem is I'm leaving 1st thing in AM for a 4 day camping trip. So how do I patch this puppy til I can get her in the shop?
Gorilla now has a clear repair tape that supposedly fix, patch & seal. I'm thinking of giving it a try. It's supposedly waterproof. Anyone used this stuff or had to do an emergency window repair. It's a small crack so I think water builds up in the seal & then leaks.
Thoughts?
JeepJunkie is offline   Reply With Quote
Old 07-23-2014, 07:39 PM   #10
Sound like a good plan. For an emergency repair, I bet clear plastic carton sealing tape would do in a pinch.
Tom
2012 Rockwood A122S
leak
