Old 09-13-2011, 08:33 AM   #11
teamgl, that's a bit chilly!
Tinsu is offline   Reply With Quote
Old 09-13-2011, 09:39 AM   #12
RV Newbie
buzzards27's Avatar
I added an additional outlet to the dedicated 20 amp micro circuit for my primary electric heater. We seldom use the micro and would never have a need to with the heater going. Feel a lot better with the heater on a 12 ga. wire.
Another thing we do is buy several RV antifreeze at a big box to use for hand flushing. Allows the DW to use the toilet, every hour, without adding water to the tank.
Originally Posted by dimurrrw
I'm assuming you have a 30 amp power feed. If you do, you should be able to run two portable electric heaters - one on high and one on low, but not on the same 15 amp circuit. Total is about 2500 watts and you have up to 3600 at your disposal. You should still be able to still run your 12 volt lights and, maybe, your refrigerator.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 09-13-2011, 10:35 AM   #13
As I tent camper, I have never worried about amp power feed. I just looked up the power feed at Indiana Dunes SP. It has 50 amp service. So, I assume the key is that it should be 30 amp service or higher, correct?
Old 09-13-2011, 06:45 PM   #14
RV Newbie
buzzards27's Avatar
They usually list the higher amperage available. Most have 30 amps and many have 50 amps. If they say 50, there should be a 50, a 30 and a 20 amp breaker available.
Old 09-13-2011, 06:53 PM   #15
flyrotor's Avatar
In addition to all the comments, you should be able to use your fridge without any issues, it won't take a lot to keep it cool.
flyrotor is offline   Reply With Quote
Old 10-01-2011, 03:52 AM   #16
Have and will use my A126, with generator powering the heat pump, no problems. Don't plan on winterizing the camper or the boat until the last second-- don't even like typing or saying the "w" word!
LakeCumberlandCamper is offline   Reply With Quote
Old 10-01-2011, 06:24 AM   #17
I have been doing some cool weather camping, 40-50 night time, and I have found that I am getting condensation on the interior of any enclosed spaces that have access to the exterior. Like storage places with an exterior hatch. The condensation is on the alu frame that penetrates the shell and on the thinner hatch door itself. I wipes these off in the a.m. or open the hatch during the day to allow drying air to pass thru.
Palomino G210
Dodge Ram 1500 Crew Cab
Kayaks
Palomino_G210 is offline   Reply With Quote
