Old 09-12-2011, 03:23 PM   #1
Winter camping in hard-sided trailers?
Have been looking at the A122. I would like to do some late fall, early winter camping. The local dealer said the hard-sided pop-ups are insulated, and should work very well in cold weather as long as your campsite has electricity.
Has anyone camped in the winter?
How do you think the hard-sided trailers would do?
Does anyone plan to camp in the winter in their A122 or similar?
I would drain all the water. No need to use the refrigerator. if that is a problem.
Primarily looking for a warm night's sleep, electric lights, and the stove for cooking.
Thanks.
Tinsu is offline   Reply With Quote
Old 09-12-2011, 05:21 PM   #2
yvesm's Avatar
The insulation is kinda thin and the seals may not be real air tight, Probably will be ok in moderately cool weather (above 20 degrees F). The furnace will run a lot so make sure you have full propane tanks. A quality electric heater is also a good idea.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 09-12-2011, 07:28 PM   #3
RV Newbie
buzzards27's Avatar
A good electric heater is must and a back up is good idea. Might as well use the power to heat and preserve your propane for a power outage.
We did a few days in below 30 weather and our electric heater ran almost non stop overnight. The walls were cold to the touch and we found several drafts that we corrected over the summer.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 09-12-2011, 07:55 PM   #4
prof_fate's Avatar
Depends on several factors - how do you like the cold? My father in law camps in his pop up, sans any heater, in single digits. But then he keeps his house at 62 in the winter...me, I like it more around 72 and hate being cold.
Besides insualtion you need to think about your water tanks and pipes - gray and black as well as fresh and the hose feeding in (if you use one, if they campground has their water on in the winter). Most companies offer a 'polar pack' option - extra insulation but more importantly heaters on all the tanks.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 09-12-2011, 08:01 PM   #5
TURBS's Avatar
I camped once in our tt that had the "winter" or "cold" weather package .
insulated and covered underside as well as heated tanks and heated sewer pipes .
went through a full 30lb tank of propane in about 5 days was no colder than 35 outside at night and 50's during the day .and I only ran the heater at 66 at night and turned all the way down during the day .
I stayed in it for 4 weeks while working at a job.
4 30lb tanks in 4 weeks .
Old 09-12-2011, 08:09 PM   #6
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
I'm assuming you have a 30 amp power feed. If you do, you should be able to run two portable electric heaters - one on high and one on low, but not on the same 15 amp circuit. Total is about 2500 watts and you have up to 3600 at your disposal. You should still be able to still run your 12 volt lights and, maybe, your refrigerator.
dimurrrw is offline   Reply With Quote
Old 09-12-2011, 08:15 PM   #7
We have an A122 and have a trip planned in late November. Our plan is to supplement the stock heated mattress with a heated blanket. Between the electric heat pump and the propane furnace it should be enough to take the chill off. The camper will already be winterized by this point so no worries about water issues. Will use stove and foil packs mostly for food.
rawlus is offline   Reply With Quote
Old 09-12-2011, 08:21 PM   #8
Mike G's Avatar
I plan on camping all winter long, as long as there is no big snow forcast. I think a single 1500 watt electric heater will be enough to keep it reasonable inside of my A122. I will winterize my camper in Nov. and just take a water container with me. I hope we don`t see one snow flake this year.
________________________
2012 A122 (SOLD)
2016 A122 SXR (New)
2016 Toyota Tacoma DCLB
Mike G is offline   Reply With Quote
Old 09-12-2011, 08:29 PM   #9
Jeep4Two's Avatar
Keep in. Ind that the a series campers heat pump shuts down at 45 degrees I believe. I would think a ceramic heater would probably be the way to go, or for short trips the LP furnace with the heat pump fan to circulate the warm air might be a good option.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 09-12-2011, 09:23 PM   #10
Location: No longer own a Forest River product, but enjoy the info on this site
We camped 3 nights and the temps dipped well below zero. We were using a 2007 Scotty Camper (retro remake) and did just fine. We were dry camping so no electric heat while sleeping at night -- just the propane heater (Atwood hydroflame 12,000 btu forced air furnace). Based on our experience we had good luck adding some extra layers between us and the elements. We put carpeting over the linoleum flooring throughout the camper and some thermarest pads between the bed and wall for some added R-values.
When using the cookstove - be sure to adequately ventilate the camper.
teamgl is offline   Reply With Quote
