Old 09-16-2013, 06:37 PM   #1
Winterizing a 2014 Rockwood A122BH
Does this unit come factory installed with a winterizing kit by Forest River for adding RV antifreeze as well as bypassing the water heater or do I need to purchase these bypass kits from amazon below? Don't want to buy if I don't need to. Appreciate your help in advance
http://www.amazon.com/Camco-35983-Qu...I2SLN6S4SMUKZO
http://www.amazon.com/Camco-36543-Pu...=ICYB1NLBGRGYJ
SurveyorWI is offline   Reply With Quote
Old 09-16-2013, 09:01 PM   #2
Does not come with a water pump bypass kit, but does come with water heater bypass.
2011 A-122
rawlus is offline   Reply With Quote
Old 09-16-2013, 09:11 PM   #3
ko777's Avatar
I use the blow out process to winterized my A128S last year. It got under -20 Celsius here in Toronto and I had no problem with my lines this season. I'm using this process again this year. Here is the link on how to winterize your rig http://www.forestriverforums.com/for...g-29237-1.html
I only use the antifreeze in the sink drain pipe. How easy/cheap is that and getting back to normal use is quick too.
Good Luck!
ko777 is offline   Reply With Quote
Old 09-16-2013, 09:44 PM   #4
1A Camper's Avatar
Went I was doing my PDI, I asked about blowing out lines to winterized. He said no problem and said to wrap a towel around the air hose and place it in the sink drain to blow the p trap out. (Take off the cap on the outside when blowing out) So no antifreeze needed.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 09-17-2013, 05:39 AM   #5
A shop vac on the outside can get most of the water out of the trap as well. That is what I do along with the line blow out if we are expecting a hard freeze.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
