Old 11-18-2012, 03:17 PM   #11
ko777's Avatar
You don't have to go to a browser just click the post in the middle and magic you see the links. I do agree the apple app does not match the browser, even the icons we cannot see it in the app and vice versa. 
ko777 is offline   Reply With Quote
Old 11-18-2012, 06:38 PM   #12
Jeep4Two's Avatar
Yep. Just tap the post, that's what I meant to say. Technically that's opening the thread in the FRF app browser.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-18-2012, 06:45 PM   #13
Jeep4Two's Avatar
On a more related note. I just winterized my A126. I'm lucky to have enough space to fit my Jeep and camper in the garage so winterizing isn't super critical.
I blow the lines, drain the heater and set bypass, empty the fresh tank on the toilet, empty the toilet filler neck, put olive oil on the seal in the toilet black tank (after thoroughly rinsing the tank several times), clean everything real good (including the toilet surfaces and toilet bowl, and push her into the garage.
I use the wheel chocks to mark the stopping point in the garage to ensure I don't hit the camper and that I'm in far enough to close the garage door.
Here are a couple picks of the 'fit'
Warning: it's sad to see a camper trapped in a garage for the winter.
ID:	21650   Click image for larger version
ID:	21651   Click image for larger version
Jeep4Two
Old 11-19-2012, 02:25 AM   #14
handbuilder's Avatar
Wow, that IS a tight fit! Using the chocks to mark your Jeep spot is a great idea!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 11-19-2012, 07:41 AM   #15
Mostly Harmless
thehamguy1's Avatar
And the camper is so clean it looks new!
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 11-19-2012, 06:54 PM   #16
Jeep4Two's Avatar
That was a pic from last year, and I had just finished giving it a full wax before winter storage.
Ill say that it was cleaner than new, at least cleaner than the day I picked it up. And she only had 16 or so camping days in her then.
Jeep4Two
Old 11-23-2012, 10:41 AM   #17
Jeep4Two, Nice looking Jeep. I would love a Wrangler, but I don't think there is any way to put a kayak on the roof. Why don't they make slots in the roof so you can attach a Yakima carrier? Tinsu
Tinsu is offline   Reply With Quote
Old 11-23-2012, 11:01 AM   #18
Jeep4Two's Avatar
There are safari racks available. They mount to points at the rear bumper and front windshield.
This one http://www.quadratec.com/products/12028_7000_07.htm is a base rack that you can add cargo racks to. Not that I recommend this one, but just an example.
Jeep4Two
a122
