Old 09-25-2016, 09:02 PM   #21
OYO
OYO's Avatar
Originally Posted by raspivey View Post
You'll never completely drain that tank, but there's plenty of expansion room. Chances are, the manual was written when none of those units came with a winterizing kit installed and that valve is a fairly recent addition.....which could mean anything in the last ten years at the rate things get updated. There's no need at all for antifreeze in the tank unless that's the only way you have to pump it through the system. It won't hurt anything if you drink traces of it but people do say it may taste/smell funny and it'll take a lot of fill/flush to get it all out since you can't completely drain it.
Bingo. We have a 2015/16 213 and there is no such valve. Well there was no such valve, I added one. But why would they put it under the unit. So much easier next to the pump with access from above?
Don't put antifreeze in your fw tank.
2016 Rockwood A213HW
2010 Silverado LTZ 4x4 Ext Cab
OYO is offline   Reply With Quote
Old 09-25-2016, 10:59 PM   #22
Originally Posted by rockfordroo View Post
X2
That valve allows you to pump the antifreeze out of the bottle without putting any in the FW tank. Why they would tell you to put it in the FW tank is beyond me, ESPECIALLY since they gave you the 3 way valve so you don't have to.
You seem to have 2 more hoses attached to the bottom of your tank. I'm wondering why. I would assume one could be the fill line, but what's the other one for? You should trace these lines and make sure you understand what they do.
UPDATE: Looking again, I see the one on the right doesn't really have a hose attached; I believe it's your tank drain.
x2 on the tank drain valve. As far as the other hoses, I believe the big one is the fill, the hose with the valve goes to the pump and the other small hose goes to the little air vent near the fill port.
You never know what you know until you ask someone!
timfuji is offline   Reply With Quote
Old 09-26-2016, 09:16 AM   #23
kdot's Avatar
Winterizing bypass valve
Brimare57, there are several things in your question and in the answers you are receiving. First, as to the manual: Unless something has changed, the manual is generic and almost useless as to particulars for your unit. There is no unit-specific manual for your unit.
Second, yes, the little valve is for draining your tank.
Third, yes, the other valve allows you to attach a small hose to it that is long enough to come out from under the trailer and into your antifreeze bottles. I had to go to the hardware store and was lucky enough to get one that fit the valve on the first trip.
Fourth, numerous people have told you not to put antifreeze in your water tank. If you've drained the tank, as you should, there is no need to put AF in it, and if you do it, it will make your water taste funny for a long time.
Finally, do make sure that you've drained the water heater and switched the bypass valves to prevent AF from getting in there before you pump any if it through the water lines. Good luck; it really isn't hard to do and NO, doing it yourself will not void the warranty. Your salesman doesn't know what he's talking about. I would really hesitate to take his advice about anything on your camper!
kdot
2016 Rockwood A 213 HW
2016 Honda Odyssey
kdot is offline   Reply With Quote
Old 09-26-2016, 09:23 AM   #24
kdot's Avatar
Winterizing Bypass valve
PS to Above: I suspect that the only reason this valve is put under the trailer so that you have to lay down and shimmy under the trailer to attach a hose to it is because it was CHEAP to do. It is a real PIA to use, compared to having the valve inside on the water pump. I suppose we should all be grateful that Forest River at least made an effort. I can only conclude what has been said many times before: the people who build campers are not necessarily campers.
kdot
2016 Honda Odyssey
Old 09-28-2016, 09:37 AM   #25
My suspicion is that it is the only way to assure the tubing from the tank to the pump is winterized and not holding residual water. That outside tubing will freeze first and is not as strong as the PEX plumbing.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 09-28-2016, 01:57 PM   #26
kdot's Avatar
Could be, Tom. I don't know actually.
kdot
2016 Honda Odyssey
Old 10-07-2016, 01:18 PM   #27
I was absolutely giddy after reading this posting last night to see if my camper was similarly equipped! It was too dark to see when I read it, but I went out there first thing this morning and sure enough it is there! I am beyond excited! Now it will winterize as easily as did my truck campers in the past. It just went from a 45 minute job to a 15 minute job. Now I won't be as reluctant to dewinterize it for weekend trips!
YEEEEEEEE HAWWWWWW!
Phillip in Scenic New Mexico
2016 T21TBHW
2006 Toyota 4Runner
ptchap is offline   Reply With Quote
Old 10-07-2016, 02:30 PM   #28
For me...anything above the flow of the fresh water tank is a bonus....i installed mine, myself within the cabinet ...a real pita....but it is done.....for this reason i suspect FR took the after tank version.....not bad, but not great....so im pretty pleased they monitor their issues in their own way.
Hey...if you cant wiggle and jiggle you own camper, your at risk for an unexpected surprise.
D-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-07-2016, 05:45 PM   #29
YEEEEEEEE HAWWWWWW!
I felt the same way.
Brimare57 is offline   Reply With Quote
Old 10-08-2016, 03:53 PM   #30
I am excited about this as well - getting ready to winterize and had never really considered what all the valves down there were for!
2016 Flagstaff T12RBST A-Frame
2002 Ford Ranger XLT Supercab 4WD V6 4.0L (232,000 miles!)
Nights camped in 2016: 37 as of 11/14
JArry is offline   Reply With Quote
bypass, winter, winterize
