Originally Posted by JArry
Do you mean backflow prevention valves?
My initial thought on Kilgore's question was that drainage of antifreeze onto the ground would not be a problem winterization-wise, because drainage due to gravity would take any water along with it, leaving the lines empty and thus not subject to freezing.
On the supply side, backflow prevention = check valve.
On the grey water/black water side, backflow prevention sometimes means a vacuum breaker valve (such as in your black tank flush line).
2011 Traverse LT, 3.6L, FWD
