09-24-2016, 08:06 PM
Winterizing Bypass Valve?
While checking out the underside of my new A213HW, I noticed this valve right next to the fresh water tank drain valve.
In the manual I received with the unit, it said to put 3 or 4 gallons of RV fluid in the freshwater tank and pump it through all the water lines to winterize it.
Is this valve used for allowing an intake line to be put directly into the bottle of RV fluid?
09-24-2016, 08:08 PM
A little farther away
09-24-2016, 08:13 PM
That's exactly what it is. Attach a hose, turn the valve towards it and kick on the pump. Make sure the water heater is bypassed and you should be able to do it with less than a gallon on that trailer.
09-24-2016, 08:22 PM
Absolutely, positively under ANY circumstances do NOT add RV antifreeze to the FW tank, you will smell and possible taste it for a long time.
09-24-2016, 08:43 PM
X2
That valve allows you to pump the antifreeze out of the bottle without putting any in the FW tank. Why they would tell you to put it in the FW tank is beyond me, ESPECIALLY since they gave you the 3 way valve so you don't have to.
You seem to have 2 more hoses attached to the bottom of your tank. I'm wondering why. I would assume one could be the fill line, but what's the other one for? You should trace these lines and make sure you understand what they do.
UPDATE: Looking again, I see the one on the right doesn't really have a hose attached; I believe it's your tank drain.
2011 Traverse LT, 3.6L, FWD
09-25-2016, 09:32 AM
Originally Posted by rockfordroo
X2
You are correct rockfordroo. The valve on the right is the tank drain.
09-25-2016, 09:38 AM
[QUOTE=rockfordroo;1325922]X2
"Why they would tell you to put it in the FW tank is beyond me, ESPECIALLY since they gave you the 3 way valve so you don't have to."
I completely agree rockfordroo. But the manual indeed says to pour a few gallons in the fresh water tank. To make matters stranger, when I picked up the unit from the dealership, the rep was very vague when I asked him if there was a RV fluid intake hose somewhere. He said if a customer winterizes the unit, it voids the warranty. Maybe it does, but I am not about to pay someone to do something that is so simple.
09-25-2016, 09:40 AM
Does anyone know what size hose will fit the valve? Please advise.
09-25-2016, 09:50 AM
Most likely 1/2 hose or PEX, you should be able to find that at Lowes or a Home Depot.
09-25-2016, 10:09 AM
[QUOTE=Brimare57;1326175]
X2
This sounds like the salesman's lips were moving again (that's when you know he's lying!)
09-25-2016, 10:18 AM
[QUOTE=rockfordroo;1326208]
At the risk of violating forum rules....
Salesman = Politician = Salesman...
/political rant.
09-25-2016, 01:15 PM
[QUOTE=Ford Idaho;1326218]
/political rant.
I think you're safe on that one as you've just stated a well recognized fact.
09-25-2016, 02:31 PM
X2
I am looking right at manual now and it surely says to pour the anti-freeze in the FW tank ...
Unbelievable
Allan and Angie
with our little dog Phoebe
________________________
2018 Hemisphere 272rl
2017 Ford F250 XLT 4x2 6.2L 3.73
09-25-2016, 02:48 PM
[QUOTE=alarge1;1326431]
Unbelievable
The only reason I could see would be if you can't fully drain your FW tank.
09-25-2016, 02:53 PM
Draining all tanks is the first item in the list of instructions
Allan and Angie
09-25-2016, 03:36 PM
You'll never completely drain that tank, but there's plenty of expansion room. Chances are, the manual was written when none of those units came with a winterizing kit installed and that valve is a fairly recent addition.....which could mean anything in the last ten years at the rate things get updated. There's no need at all for antifreeze in the tank unless that's the only way you have to pump it through the system. It won't hurt anything if you drink traces of it but people do say it may taste/smell funny and it'll take a lot of fill/flush to get it all out since you can't completely drain it.
09-25-2016, 03:59 PM
EXACTLY!
Neither the FW tank or WH have to be completely empty, because there's room for the frozen water to expand.
It's the places that are narrow that are in danger.
Water lines are #1 danger area.
09-25-2016, 05:47 PM
The manual give complete instructions to the consumer for winterizing. So the manufacturer support customers doing it. The salesnerd was, er, misinformed.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
09-25-2016, 05:54 PM
It's a case of the dealership hoping to get to charge for winterizing.
09-25-2016, 06:35 PM
BINGO!!!
