Old 09-12-2013, 07:20 AM   #1
proskin's Avatar
Winterizing question
Sad to say we have finished our camping for the season. We really enjoyed our new A-frame camper. I have a 12 DDST. Here is my winterizing question.
I completed all the major winterizing steps.
- I emptied and bypassed the hot water heater.
- Emptied the water holding tank.
- Filled it with 3 gallons of RV antifreeze.
- Ran the anti-freeze through the sink and outdoor shower
- Finished by opening the low-point drains under the sink for a few seconds.
MY QUESTION:
Looks like I still have a lot of anti-freeze left over in the freshwater holding tank. Do I leave it in there for the winter or do I drain it out as much as I can? I would think it wouldn't hurt either way but I figured I would ask.
Thanks for your help. This forum is awesome. Lots of great information, tips and tricks.
proskin is offline   Reply With Quote
Old 09-12-2013, 08:07 AM   #2
Professional Curmudgeon
If you are getting solid pink out of each and every faucet and shower sprayer, you are good to go. That's both hot and cold faucets and sprayers. Don't forget the outdoor shower if you have one.
Go ahead and drain the water tank. If you let it sit for any length of time, you'll likely stain the inside of the tank.
For the next time - rather than introducing antifreeze into the drinking water tank, check your water pump. In between the water tank and the pump there may be a valve with a plastic tube. This is where you introduce the pink stuff into your lines. Simply turn the valve and stick the tube into the antifreeze jug. Turn on the pump and go through the camper opening and closing valves. Start with the sink or shower closest to the pump and work your way to the one furthest away from the pump. Once you have solid pink coming out of all of them, you can turn off the pump, disconnect the bottle, and return the valve to it's normal position.
Finally, after draining your water heater, be sure to re-install the drain plug to prevent critters from setting up housekeeping inside the tank.
One last tip: get a small roll of Tyvek fabric from Lowe's or similar, cut squares slightly larger than the access covers on your water heater, refridgerator, etc. Open the access cover, then close it with the Tyvek sheet trapped between the cover and the edge of the hole. This will help keep wasps and spiders from getting into these areas while your camper is in lay-up.
wrvond is offline   Reply With Quote
Old 09-12-2013, 10:55 AM   #3
Triguy's Avatar
wrvond is right. Drain the AF from your fresh water tank. And, in the future, know that you do not need to put AF in the FW tank as there are better alternatives.
Here we have some threads that I want to point out to you that address winterizing as a whole. Pick and choose, of course, but should be helpful for you...
Winterizing - Forest River Forums
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-12-2013, 02:31 PM   #4
proskin's Avatar
That was very helpful. I do have a question. Should the anti-freeze fill up the glass to the water filter under the sink? I don't see any way to avoid that.
Old 09-12-2013, 02:38 PM   #5
Triguy's Avatar
Yes. Take the filter out and discard and fill the canister with the pink stuff.
Scott
2012 Shamrock 233S
Old 09-12-2013, 05:19 PM   #6
Mostly Harmless
thehamguy1's Avatar
Be sure to leave some antifreeze in the sink's P-trap. And unless you've installed it yourself, your A frame doesn't have the valve near the water pump that wrvond speaks of. However, they're not expensive or hard to install. Several of us on the A frame threads have installed them. They do make winterizing easier and I find I need just under a gallon of AF for the whole job since I don't have to put any in the fresh water tank.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 09-12-2013, 07:37 PM   #7
With the pump bypass valve you'll use less than 1 gal of the pink stuff
2011 A-122
rawlus is offline   Reply With Quote
Old 09-12-2013, 09:24 PM   #8
How much is a water pump bypass for an aframe?
SurveyorWI is offline   Reply With Quote
Old 09-12-2013, 10:03 PM   #9
Mostly Harmless
thehamguy1's Avatar
This is what I got: http://www.amazon.com/gp/aw/d/B0006JJ588
Except I got it at an RV parts store.
2011 Rockwood A128
60W solar system
Old 09-12-2013, 10:05 PM   #10
Originally Posted by thehamguy1 View Post
This is what I got: Camco 36543 RV Pump Converter Winterizing Kit:Amazon:Automotive
X2
2011 A-122
winter, winterize
