Old 10-11-2015, 07:25 PM   #11
BooBoo23's Avatar
Don't forget to open the low point drains since you can't blow that water out. Put the plug (or close the valves) back on/in to prevent insects from taking up home in the lines. I'm not sold on just blowing the lines out, I still prefer the RV/Marine Antifreeze. It only take 2 or 3 gallons, less than $10 to do it.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is online now   Reply With Quote
Old 10-11-2015, 09:27 PM   #12
Low points ?
Boo,
I was not aware of any low point drains on my 122s. Where might they be located?
Thanks for the help.
Tony w is offline   Reply With Quote
Old 10-11-2015, 10:07 PM   #13
BooBoo23's Avatar
I'm not familiar where they are on a Roo. They will be two short pipes extending under the trailer just like there would be for the FW drain. The low point drains most times just have a cap on them, no valve. One many times is blue and the other is white. Not saying you have them but chances are that you do, every RV with a water system has them. There is probably no mention of them in any manual either.
Old 10-11-2015, 10:27 PM   #14
1A Camper's Avatar
On my A frame, they under the sink and on the floor.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 10-12-2015, 06:31 AM   #15
Originally Posted by Tony w View Post
Boo,
On the floor of the sink cabinet next to the water pump. Look for the "T" handles that get in the way of using the cabinet space.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 10-12-2015, 02:47 PM   #16
How long is your city water connection line? Just asking to see if it is the same as in my 2514g pop up. Mine is lucky to be 18 inches long. I can easily see where it connects from the sidewall and runs to the pump. I unhooked it to install a bypass and just blew into it and then held it down to see if anything else ran out.....nothing. Then hooked it back up in-line.
61cubby is offline   Reply With Quote
winter, winterize
