Old 10-03-2014, 12:50 PM   #1
Question Winterizing Specifics for Rockwood 194HW
I am a newbie and I need help in winterizing my hard top. Specifically using antifreeze and how do I get it into the lines. Do I have to disconnect hoses coming out of the pump. I have not been able to find any clear, concise instructions on this model, just pop ups/hard tops in general. Any help or a link to a You Tube video would be appreciated.
Tim
KEMO1921 is offline   Reply With Quote
Old 10-03-2014, 02:27 PM   #2
If you plan to use anti-freeze, you will need to pick up a fitting that attaches to the intake on the water pump. Be sure to use the valves to isolate the water heater so no antifreeze is going into the heater. Besides filling the waterlines, you will need to put about a quart of anti-freeze in each of the drains. If your camper has the cassette toilet, make sure you drain the flush water and add anti-freeze to that as well.
jimdic is offline   Reply With Quote
Old 10-03-2014, 02:34 PM   #3
Kaadk's Avatar
x2.
If you're looking for a permanent solution, see about picking up a antifreeze fill kit, like this one from Camping World.
That way you only have to disconnect the plumping once. From then on in subsequent years it's just the turn of a valve.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 10-03-2014, 03:43 PM   #4
I trust it goes without saying that you do not use regular antifreeze (toxic).
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
rockwood, winter, winterize
