Old 04-20-2019, 09:49 AM   #1
bruc33ef's Avatar
Wire Gauge Significance in 4-pin SUV to 7-pin A-Frame Connection
(2018 Flagstaff T21TBHW; 2018 Kia Sorento 6cyl,AWD)
I had an auto-electric shop wire up my 4-pin Kia to 7-pin to connect to the a-frame. They used 12-gauge wire for the power wire to the car battery, I found. Is this enough to trickle-charge the a-frame battery and run the fridge while driving or should they have used 10-gauge? Is the voltage loss that significant, ya think? Thx
2018 T21TBHW
2018 Kia Sorento 6cyl AWD
bruc33ef is offline   Reply With Quote
Old 04-20-2019, 10:04 AM   #2
What refrigerator? Guessing an absorption LP/115vAC/12vDC version. Running on 12v provides the least cold. Run it on LP on the road and don't worry about the 12v power needs. Tow vehicle alternator voltage regulator is only intended to maintain the vehicle battery and will merely trickle change the trailer battery especially with the voltage drop in the long wire between the alternator and trailer battery.
10 gauge is better. Are all 7 poles in the adapter powered? If they are and are not controlled by a relay to the ignition the 12v refrigerator and other trailer loads will suck the tow vehicle battery dry when the engine isn't running.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 04-20-2019, 11:06 AM   #3
bruc33ef's Avatar
-- Chuck
Chuck, the stock 4-pin harness is connected to a standard 7-pin adapter. The remaining wires on the 7-pin are as follows:
The black (power wire) is spliced to a 12-gauge wire which goes under the vehicle, through a 40-amp inline circuit-breaker to the battery.
The yellow wire is for 12v power.
The white (ground) wire is grounded to the chassis.
The blue (brake) wire is unconnected (I use the Curt Echo wireless brake controller which doesn't require the blue wire connected; it senses brake action through the brake-lights, as I understand it).
No ignition relay, but I can't see how the trailer could drain the vehicle battery via the controller (which fits between the vehicle and trailer 7-pin connectors and is powered by the vehicle only; so when the vehicle is off, the controller is off). Thanks.
2018 T21TBHW
Old 04-20-2019, 02:38 PM   #4
Assuming a maximum of 20 feet from the vehicle battery to the trailer connection would allow 10 Amperes using 12 AWG wire. If your run is shorter (likely) then that value increases based on the length so you are OK. A 10 Ampere current availability is more than enough to trickle charge your trailer battery, probably ten times as much needed if the battery has a fresh charge before you leave. You'll have to check on your refrigerator ratings to see what it draws on 12V operation to factor that in but I would recommend using gas operation instead as other posters have stated. The refrigerator takes a very tiny amount of gas to run while traveling and works much better than 12V.
TrailerTexan is offline   Reply With Quote
Old 04-20-2019, 03:18 PM   #5
Do you have a standard or a High Wall A-frame? The fridges are very different. On a standard A-frame the fridge does not autolight. And the low height between bottom and top vents reduces the chimney effect. All of which means it is very likely that the fridge flame will be blown out by the wind as you are driving on a standard height A-frame. Which means you have to run on DC while towing or do without the fridge. That's what happened to me with my A122.
I forget the exact wattage but both the AC and DC coils are the same wattage. Because of the extra air flow the fridge cools better at highway speeds.
Unless you install a fan - I used a 12V computer case fan tie wrapped to the top vent - cooling is very hit or miss when not being towed at highway speeds. Using a battery-powered wireless outside thermometer. ($10 at Wal-Mart) I found that the fridge temp was down in the 20s after a few hours towing at highway speeds. I would then turn the fridge off until temps were back to 40 to give my TV (minivan) a chance to top off the batteries.
My new High Wall A-frame has a very different fridge that autolight and will happily run on propane while towing.
Fred W
Prev Rockwood A122 A-frame
Now Flagstaff T21TBHW A-frame
Old 04-20-2019, 03:55 PM   #6
I was not aware of the fact that some refrigerators do not have the autolight feature. This is my fourth trailer (but first A frame) and they all had autolighting. Mine is a high-wall so no worries but it is good to know that some do not. Something to watch for if you ever need to replace one.
If the AC and DC coil both use the same power rating in Watts then you can easily calculate the current difference required. For practical purposes since 12V is one tenth of 120V then the current will be ten times that at 120V for 12V. For example, 120 Watts at 120 V would be 1A and therefore the same power would be 10A at 12V. (Power is equal to the Voltage times the Current as a simple calculation...don't get me started on resistance vs impedance and phase angle/power factor because I can talk your ear off and bore you to death. Just ask my wife. You don't really want the actual calculations but this simple approximation is more than adequate for your use here.)
Old 04-20-2019, 05:22 PM   #7
bruc33ef's Avatar
Fred W
I have the same model HW as you (2018) so the same fridge, I assume -- Dometic 2354. It's nice to know I can run it on propane w/o the flame blowing out. I will get one of those thermometers -- great idea -- to see exactly what's going on; I'm very curious now. Thanks!
2018 T21TBHW
Old 04-20-2019, 05:31 PM   #8
Yes, that is the same fridge as in my 2019.
Old 04-21-2019, 01:59 PM   #9
Kia?
Forget about the wire, just what are you towing with a Kia that requires a 7 pin connector?
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is online now   Reply With Quote
Old 04-21-2019, 02:37 PM   #10
bruc33ef's Avatar
2,600 lb Flagstaff T21TBHW. Has brakes and so needs a 7-pin.
2018 T21TBHW
a-frame, frame
