Looks good. I made some for the inside of our Forester to block the skylights.
Bought a sewing machine, learned how to use it, then made some similar using reflectix, heat material, then better looking material in the side that shows.
Used Velcro and command strips to hold in place.
You are correct that things like that make a huge difference in the comfort level inside.
The only thing I have found is the command strips don’t like the heat that well, at least the smaller ones I used initially. The glue did let go from the heat.
Need to use the upgraded command Velcro strips.
I put a strip of Velcro all the way around the shades I made to just need to change the piece in the skylight opening.
We should get together and start a cottage industry since it seems nobody makes things like we did [emoji3]
2014 3051S - First RV for us
