Old 05-29-2014, 07:11 AM   #1
5th wheel hitch
what hitch do you use for your Trilogy ? I'm looking at a reese 20k hitch and wanted see what the group thinks is the best setup.
GaryanJane is offline   Reply With Quote
Old 05-29-2014, 07:31 AM   #2
lgray's Avatar
I use the Curtis Q20 (no slider) standard bed, 2011 Silverado 2500 HD, no problems with clearance. This hitch has three grease fittings and provides side-to-side movement/flexibility. Towing a 2013 Trilogy 3650 RL.
lgray is offline   Reply With Quote
Old 05-29-2014, 07:43 AM   #3
Tom & Gayle
I have a curt Q20 in my GMC 3500 HD. Pulling a 3650 RL. It works very well.. No problem with clearances also. As long as I keep the trail air pin box inflated properly.
Tomngayle is offline   Reply With Quote
Old 05-29-2014, 11:16 AM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I had the Curt Q20 on a previous truck and would have kept it, only Dodge didn't offer proper adapter rails for the 2013 trucks so I ended up buying the Andersen Ultimate 5th wheel hitch. It is good up to 24000#, only weighs 75# and has 3 height settings. For me it would be a tossup where the Andersen would probably win because 1 person can install or remove it within 2 minutes with no sweat.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-31-2014, 10:49 PM   #5
gauchoverde's Avatar
I have a trilogy touring with the trailair rota flex pinbox. I have a trailer saver TS3 by Hensley Manufacturing hitch mounted in my truck. I like the damping action of the TS3.
Sent from my SPH-L720 using Forest River Forums mobile app
gauchoverde is offline   Reply With Quote
Old 06-01-2014, 06:12 AM   #6
RKR
RKR's Avatar
B&W is pretty solid. We've been using their products for our company pickups down here in the oilfield for years. They get abused on a regular basis and hold up.
I opted for the Turnover Ball gooseneck set up with a Companion slider. It was a little pricey but I knew they made solid products so it was worth it for me.
RKR is offline   Reply With Quote
Old 06-24-2014, 11:10 AM   #7
Reese 20 on 3850 D3
chaimemet is offline   Reply With Quote
5th wheel, hitch, wheel
