Old 05-26-2014, 07:08 AM   #1
gauchoverde's Avatar
Air conditioner
Yesterday the outside temperature reached 83so I turned on the rear air conditioner and closed off the bedroom. It was able to drop interior temperature to 78 but no lower. I will need to measure the temperature at the vents but the heat pump mode works very well. Makes me wonder about those 100 deg days.
Sent from my SPH-L720 using Forest River Forums mobile app
gauchoverde is offline   Reply With Quote
Old 05-26-2014, 11:24 AM   #2
which Trilogy do you have ?
GaryanJane is offline   Reply With Quote
Old 05-26-2014, 12:39 PM   #3
36re. It has two 15000 btu ac with the rear one doubling as a heat pump
Old 05-26-2014, 09:30 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
We had 88 deg F. one day last week and the rear AC had no problem bringing the temp. down to 75 deg. with the chill grill open and the upstairs closed up.
We are boondocking right now and have to run the generator for the AC, the rear AC works fine but the 20 Amp breaker for the front AC on the generator keeps tripping after a minute or two, so that's a bummer.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-26-2014, 10:03 PM   #5
I'll try it next time with the chill grill open
Old 05-26-2014, 10:08 PM   #6
I got an amp reading of 22 when running the front ac and 17 when the rear ac was running. That might be why your 20 amp breaker is tripping on your generator.
Old 05-26-2014, 10:12 PM   #7
Strange, the only difference I see is the rear AC has the heatpump and the front doesn't.
Old 05-27-2014, 11:30 PM   #8
Although we aren't in the 100s yet, we can only run one AC at a time. No problems with the ability to run two - but each one brings the temperature so low we almost need a heater to get warm again!! We have the 3850 and these are the best ACs we have ever owned in any RV.
JD
Lawrence, JD and JJ
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 05-28-2014, 02:46 PM   #9
lgray's Avatar
You may want to cover the stair vents that cool the basement. We did and camped last week in the low 90's outside and kept our 3650 RL in the mid-70's, front 1350 btu and rear 1500.
lgray is offline   Reply With Quote
Old 05-29-2014, 07:47 AM   #10
I have the 36ret3 And my front unit seems to struggle assisting the rear unit and the temps have only reached 90 so for, and we are under some shade trees .Last week my rear ac quit. I was told by dealer had to contact ac manufacture for warranty coverage. I contacted them and still waiting on my unit to arrive to replace it. My unit went down on the 22cd. I had to go buy a portable floor model 12000 btu ac unit and vent exhaust hose out window where we could camp for memorial weekend. It done the job. Note my Rv was purchased in November 2013 so It hasn't been used that much, hope the one they send is a better ac unit.
d69stang is offline   Reply With Quote
air conditioner
