Old 09-14-2014, 04:27 PM   #1
lgray's Avatar
Alternative to RV AC Unit?
Last week while traveling on business, my hotel room was equipped with a Mitsubishi ductless AC unit that kept the room like a meat locker, but more importantly to me, I could not heat it running. The circulation of air was far superior to anything I have seen. Just beginning to research, but it appears that the primary manufacturers are LG and Mitsubishi. The AC units come with or without heat pumps which means with or without the outside unit. Below are links to ceiling mounted 2.0 ton (24,000 Btu) and 2.5 (30,000 Btu) Mitsubishi’s. They make a wall mounted unit, like my hotel room, but probably not a good fit for a fifth wheel.
https://www.younits.com/pca-a24ka4-c...btu-2-ton.html
https://www.younits.com/pca-a30ka4-c...u-2-5-ton.html
lgray is offline   Reply With Quote
Old 09-14-2014, 04:44 PM   #2
Standard AC and Heat Pumps both require an outside Condensing Unit.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-14-2014, 04:48 PM   #3
lgray's Avatar
Unless I am missing something, not these, "cooling only units", Mfg. site
Mitsubishi Electric US, Inc. Cooling & Heating | HVAC
Old 09-14-2014, 04:50 PM   #4
Unless they are different from the ones I installed, you need an outside condenser. These are just the air handlers.
Old 09-14-2014, 04:52 PM   #5
Problem would be the larger ones are 220v. Wouldn't work in an RV.
Old 09-14-2014, 04:55 PM   #6
This is an example of a ductless system. The condenser, air handler and thermostat. You supply the copper lines.
Old 09-14-2014, 04:55 PM   #7
Forgot the picture
Name:	ImageUploadedByForest River Forums1410731757.668251.jpg
Old 09-14-2014, 05:03 PM   #8
lgray's Avatar
Forgot the picture
Attachment 62809
Thanks, and I did see these combinations, however, website for the "P" series, Mistsubishi site gives you the impression that the outside unit is not necessary. Again, just starting to look and don't need one just yet...they sure are nice...
Old 09-14-2014, 05:30 PM   #9
It states indor unit is powred by outdoor unit.
harderd is offline   Reply With Quote
Old 09-14-2014, 05:31 PM   #10
How do they remove the hot air and moisture?
