Old 02-15-2016, 12:54 PM   #1
CC38EL's Avatar
Another ceiling fan issue
Does anyone have a user manual or instruction manual for the ceiling fan? Ours is turned off because it shorts the circuit breaker to ground.
Trying to find the short and any info on this fan would be helpful.
Jim
Currently without a rig
CC38EL is offline   Reply With Quote
Old 02-15-2016, 01:30 PM   #2
dieselguy's Avatar
It's no different than any other fan/light combo. Power (black) neutral (white) ground (green or bare wire). The light wire is sometimes attached directly to the power wire sometimes to a separate wire (maybe blue). With the breaker switched off, disconnect the power wire at the fan and try the switch again after you turn the breaker back on. If the breaker still pops it's the switch or wiring from the switch to the light. If the breaker doesn't pop, it's the fan assy or it was miswired to start with. If you are uncomfortable with electricity ... call an electrical tradesman.
dieselguy is offline   Reply With Quote
Old 02-15-2016, 01:44 PM   #3
Oaklevel's Avatar
Just curious is your ceiling fan must be 110V ?? Ours is 12V. but we have a different make trailer.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 02-15-2016, 02:34 PM   #4
CC38EL's Avatar
I'm good with the electrical. I'm looking for the 'this is how to take me apart' info.
Before I just start taking screws out.
Jim
Old 02-15-2016, 02:34 PM   #5
CC38EL's Avatar
And it's 110v .
Jim
Old 02-15-2016, 02:46 PM   #6
dieselguy's Avatar
On my Keystone and Cedar Creek fivers ... vent fans have been 12 VDC ... ceiling fan like in stick house have been 120 VAC.
Here's a generic installation
http://community.homedepot.com/howto...065000000006O2
Old 02-15-2016, 03:22 PM   #7
Pickin' & Campin'
Ceiling Fan Flush Mount | The Home Depot Community
Our ceiling fan (stick house kind) was supposed to be available as a 12v option when we ordered our unit. There was an order line for it and
we ordered as such. When it arrived, it was 110v. I contacted the factory and was told they were phasing out the 12v models.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 02-15-2016, 03:46 PM   #8
Oaklevel's Avatar
That's interesting but you can still get the 12V ceiling fans on line from places like Camping World. I wonder if there is a reason why they stopped the 12V. Our RV tech when we got the trailer did say not to reverse it while it the blades were moving as some of the 12V fans would mess up the circuit boards.
1966 Mustang GT
1986 Mustang SVO
Old 02-16-2016, 12:41 PM   #9
Possibly a pinched wire in the base of the unit.
Harkerr is offline   Reply With Quote
Old 02-17-2016, 07:53 AM   #10
nosaint3
On my trilogy it was the switch on the wall that was bad. The fan turned but real slow and the new switched fixed it.
nosaint3 is offline   Reply With Quote
fan
