Originally Posted by salexander
Hi I was wondering if anyone has experience their awnings not coming out on their own. We picked up our new trilogy last week and our awnings just unroll when trying to put them out. If someone assists you and pull out on the awnings while they start to unwind after the first bit they will come out fine on their own. also once I got them out I noticed that 1/3 of the LED light strip on my front awning was not working.
I ran into the same problem with my awnings yesterday. After retracting them in the morning they would not come back out in the evening.
Today I pulled the customer control panel apart to look for voltage on the back of the switches. Neither one of them had the 12v power available. So, that means either a blown fuse of bad/broken wire/connection somewhere.
In the basement on the curbside, there is an access panel. Behind it are a bank of 15 AMP fuses.
Not sure why picture is turned sideways. The left side of the picture is the TOP and the right side is the bottom. I found the THIRD fuse from the top was blown
In the picture above, it is shown as the top fuse (it's been pulled from the circuit). But! Keep in mind that it is really the third from the top. Try checking and changing that fuse and see if it is your problem. It was an easy fix.
Also, note that I added two spare fuses at the bottom of the terminal strips. There were three empty slots on mine (seen at the right side of the above pictures). Nothing like trying to locate a fuse when it is raining or worse outside. Having them handy will be a time saver in the future.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
