Old 07-11-2014, 10:50 AM   #1
Call from Alko Manufacturing
Received a call from Alko on Wednesday of this week. The rep told me I would receive a letter and technical bulletin regarding the bolts on our axles. Told me to take it to a dealer and have the torque checked on all bolts. This will be at no cost. He told me there are 16 bolts all of which should be torqued to 100 ft lbs. Told me it is a simple process. Was going to do it myself, but decided better to take to a dealer just in case there is a problem later down the line. I have a 2014 Trilogy Touring, purchased in May of this year.
We are not traveling now so I am waiting on the letter. Thought I would pass this on for other with the same coach who may be moving around. Do not know if this applies to all 2014 coaches or not (Trilogy and Trilogy Touring).
retamaman is offline   Reply With Quote
Old 07-11-2014, 01:03 PM   #2
gauchoverde's Avatar
I also have a 2014 trilogy touring with Alko axles. Maybe I missed it but what is the problem with your axles?
gauchoverde is offline   Reply With Quote
Old 07-11-2014, 01:36 PM   #3
Possible loose bolts where axle attaches to frame.
Old 07-11-2014, 02:51 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I got that same phone call from Dynamax. I will go and check the torque myself and then take it to a dealer, might be nothing who knows. Seems like the torque on the U-bolts varies between axle type.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-14-2014, 01:13 PM   #5
I too received the call from Alco. I was surprised that they called me because I had the MOR/ryde Independent Suspension system installed when I ordered the Trilogy. Odd that Dynamax did not pass that on to Alco...
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 07-19-2014, 01:25 PM   #6
I've got Lippert axles. My brakes are completely screwed up. Lippert won't pay to fix them unless I buy the parts first. I wish I had Alko axles.
Marks is offline   Reply With Quote
Old 07-25-2014, 07:17 AM   #7
Name:	ImageUploadedByForest River Forums1406290389.189115.jpg
Make sure you have your wheel bearing checked. I always spin my wheels when the stabilizers are down just before I depart and listen for noise. Last week I lost a wheel going down the highway just about 10 miles after I left.
dnovak is offline   Reply With Quote
Old 07-25-2014, 09:10 AM   #8
Incheon, S. Korea
BigBaron's Avatar
Did you find the hub? It looks like it ripped right off the axle!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-25-2014, 10:07 AM   #9
I did, wheel plus hub little heavy, alko is replacing the complete axle. I hope to get it today, the coach has been in sf all week.
Old 07-25-2014, 01:01 PM   #10
Checked the nuts on the axle bolts. Of the sixteen nuts, only five were at the proper torque (100 ft lbs). In fact six required several pulls on the torque wrench to get them tightened properly. Still plan to take to a dealer just in case something happens down the road (no pun intended).
