Old 12-04-2013, 07:31 PM   #1
ceiling fan
Just picked up my trilogy after warranty work. One of the problems was the rear fan was turning slower than the front. After replacing the fan the problem remained. The tech then discovered that there is a very small slider on the side if the switch that changes the speed. This is on the wall switch for the front fan and the ceiling switch under the rear cabinets for the rear fan.
Priusron is offline   Reply With Quote
Old 12-04-2013, 08:25 PM   #2
lgray's Avatar
Had no idea, thanks for passing along this valuable information.
lgray is online now   Reply With Quote
Old 12-07-2013, 11:20 AM   #3
Tom & Gayle
Thank you. When we bought our Trilogy in July, I questioned the same problem with one of our fans. After the tech checked it out, we were told it was just a difference in fan motors. After reading your info I checked the switch and sure enough that obscured little slider was in the mid position. Both fans the same speed now. Thank you again.
Tomngayle is offline   Reply With Quote
Old 12-07-2013, 10:43 PM   #4
Make sure the chain is in the position to be on high. The dealer I purchased from got me a new fan but it took 2 mos. The dealer I took it to for warranty work installed a new fan and gave me the old fan. They then discovered the switch. I now have 2 replacement fans.
Old 12-08-2013, 02:56 PM   #5
Iwannacamp's Avatar
Dang... One would think the warranty department or a TSB or someone reading the options list would know this. Makes you go DUHHHHH
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 12-09-2013, 08:53 PM   #6
Wow! I checked ours immediately and there it is - a little switch on the side. Thanks for posting this info. We keep learning new things about our 2 month old Trilogy.
Lawrence, JD and JJ
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 12-12-2013, 06:40 AM   #7
thanks for the post
GaryanJane is offline   Reply With Quote
fan
