Sorry for being MIA for awhile.......I also noticed this, but if you are using the furnace I would recommend NOT blocking them off as they are technically used for cold air return to the furnace, but if you are not using furnace I would be ok to cover them , I use a section of memory type foam wrapped in material that closely matches the interior to cover them when we are not running the furnace, it seems to work pretty well
2021 Riverstone Legacy 39RKFB / 2021 Ford F350 6.7L DRW / 2021 Palomino 2910
