Old 06-23-2015, 10:31 PM   #1
Exterior Door Lock and FOB
Our new 2014 3650RE come with a FOB that worked but two keys that didn't work . The dealer was honest and was unable to get the new latch assembly and lock in time for our PDI . I received a new entire lock assembly with two keys and a new FOB. The old FOB worked with the old assembly well.
Does anyone know what brand of lock/FOB assembly they are installing ? The packing slip from FR only has a part # and the lock and FOB have nothing on them form the manufacture. Trying to sort out how to get both FOBs to work on the new lock assembly.
My dealer is 8 hours away and has zero experience with the lock assembly .
Teddy Bear is offline   Reply With Quote
Old 06-23-2015, 11:09 PM   #2
Taranwanderer's Avatar
I'd post a picture of what you have, we may be able to ID it from there...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-24-2015, 07:55 AM   #3
Name:	ImageUploadedByForest River Forums1435150154.483151.jpg
Here is the FOB and latch . I did find out there is a remote controller that hooks to the latch in the door. Now I am looking for the info on the remote controller that operates the latch . I have read that some suppliers of FOBs for RVs place a sticker on the back with the code , unfortunately I don't have any stickers on my FOB indicating code or supplier. Also opened up the FOB and there is nothing inside but the battery , and electric transmitter chip. No dip switches . Nothing
Old 06-24-2015, 08:51 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Congratulations to your new Trilogy
The control board is behind a panel in the basement storage area under the shower, that's pretty much where my knowledge ends - sorry.
Your best bet is to call or email Dynamax for the instructions, I have found them to be surprisingly responsive. Dynamax RV - Contact Us
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 06-25-2015, 06:39 PM   #5
Thanks appreciate it.
It's a good start😃😃
Old 06-27-2015, 05:31 PM   #6
Teddy Bear, please be sure and post what you find out. We just purchased our 36RL last month and the key pad did work on our first outing. I've been plugged in at home to with a reducer to110 and the key pad does not work. Maybe it has to be plugged into a 50 amp plug to work. The key fob has not worked at all.
Thumper7 is offline   Reply With Quote
Old 06-29-2015, 09:44 PM   #7
Found everything I required on this web site poplocks.com . They were the original suppliers of the FOB, auto lock driver for the deadbolt and the key pad. I did find on there website that they have contact hinges that are used to hard wire up the power to the lock and deadbolt . ( no batteries required )
Possibly your contact hinge is not connecting , they have some troubleshooting tips and a sign in web site to send in your help .
Good luck .
Old 06-30-2015, 06:07 AM   #8
Thanks for the info.
Old 06-30-2015, 01:43 PM   #9
gauchoverde's Avatar
If you use the contact set up the power drops to the lock when the door is open dropping the programed entry code.. I replaced the hinge and all works well now.
gauchoverde is offline   Reply With Quote
door, exterior
