Old 12-01-2015, 06:45 PM   #11
CC38EL's Avatar
This is the rear spring shackle on a 2014 rig built on a 2013 chassis. My welder brother in law has suggested 3/8" stock welded to the other shackle sides for reinforcement. Going to do that at home in the spring.
Jim
Currently without a rig
CC38EL is offline   Reply With Quote
Old 12-01-2015, 08:46 PM   #12
Shackle plates
There are two on each end of each spring. They are about 3 inches by 1.5 inches. What happens is the bolts wear the holes in the plates until failure. Need to disassemble to inspect. One of mine failed at 30000 miles but all were worn. Mine is a 36 foot FR 5th wheel.
Harkerr is offline   Reply With Quote
Old 12-02-2015, 07:37 AM   #13
CC38EL's Avatar
Thank you. Will do that when we get in for repairs as the repair guy will have to disassemble the leaf spring to weld.
Jim
Old 12-02-2015, 07:46 AM   #14
Before you start welding, disconnect your RV battery. If not you could fry your electronics when the welder clips on to the frame.
18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 12-02-2015, 09:48 AM   #15
Jack350's Avatar
When I installed my Correct Track Alignment system I also replaced shackle plate connectors, bushings and bolts with the upgrade kit. All original equipment was in need of replacement after just two years. Here are pictures of the finished install.
2017 Open Range RES 347, 2017 F-350 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 12-02-2015, 10:02 AM   #16
CC38EL's Avatar
That install is much more robust than the factory original.
Definitely heavy duty. I guess LCI saved a few bucks on their install. Spent just enough to get the logo on their frame.
Jim
Old 12-02-2015, 10:09 AM   #17
Who Dares, Wins
doc73's Avatar
Even that wore off after a few weeks... Sticker peeled off!
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-02-2015, 11:45 AM   #18
Jim Schings's Avatar
X2 on the weld. No penetration. Surprised it didn't break long ago...
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 12-02-2015, 12:11 PM   #19
I have been through 2 hybrids that were both on LCI frames and had no issues. Granted one was only 5000 GVWR and the other 6000 GVWR. I am about 99.9% sure our new Roo is coming on an LCI frame. Not one weld on either of those frames looked good. Usually when a weld does not look good its a pretty good possibility its not good. I think if it was a widespread problem there would be recalls all over NHTSA. There are hundreds of thousands of LCI frames on the road. Not talking about anyone here, but you also don't know how many people are abusing stuff. I know a couple people who should not be allowed to tow anything at any time.
Add to that everyone, myself included, is obsessed with low price.
I once noticed an ad online for welders at LCI a few years ago, I think it was on the website of the Elkhart Truth newspaper. The starting wage offered was $12 hr. You don't get much of a welder for $12 an hour. You get a guy like me. Someone who thinks he can weld. I won't sell myself short, I am one hell of a melter. I just went and looked there again and no ad for LCI but they have a temp staffing agency looking for welders. You get even less of a welder from the temp agency?
Mr Havercamp is offline   Reply With Quote
Old 12-02-2015, 02:47 PM   #20
CC38EL's Avatar
We're all fixed. And as noted, one side of the bracket had no penetration.
New bracket and weld looks great. I'm not a weld expert, but my guys weld looks better than original.
Jim
