Old 12-09-2015, 09:40 PM   #21
Originally Posted by Jack350 View Post
When I installed my Correct Track Alignment system I also replaced shackle plate connectors, bushings and bolts with the upgrade kit. All original equipment was in need of replacement after just two years. Here are pictures of the finished install.
Attachment 95403
Attachment 95404
Do you have a part number for the shackle plate connector upgrade kit? I don't want to hope that I will "just" need a welder next time this happens...
Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 12-10-2015, 10:40 AM   #22
Jack350's Avatar
Wow... Another bad weld picture. What year trailer and miles driven on your trailer. I installed the Mor Ride kit on the trailer in my picture and the link will get you to some options.
http://www.amazon.com/MOR-ryde-UO120...GZXVBVVWFG6A4D
Keep safe.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 12-10-2015, 10:54 AM   #23
Thank you for the link. Trailer is a 2015 Trilogy 38RE that we purchased new
(leftover) in July, failure was noticed with a grand total of 1845 miles on rig since we left dealership.
I also find it interesting that every failure I have seen has been the right rear shackle....
Trilogy 38RE
Old 12-10-2015, 11:14 AM   #24
Jack350's Avatar
Right turns are tighter than left turns and would probably put more pressure on the rear right shackle. Your picture does not look like the weld had much penetration. I would have all the other shackles checked during repair to be safe.
Old 12-10-2015, 12:06 PM   #25
My BIL who had welded forever suggested that each shackle should have a 3/8" strap welded over it.
He also said the right rear wheel takes the most abuse leading to failure somewhere in the chassis.
Going to look into that in the spring. Right now, sitting pretty in central florida for the next few months.
Jim
2019 Coachmen Mirada Select 37LS
CC38EL is offline   Reply With Quote
