Old 01-03-2014, 05:54 PM   #11
A heat pump works by taking heat out of the outsidevair and releasing it inside. It is good down to about 35. Then you have to use your emergency heat. That would be our furnace. If it is above 35 I don't want the furnace using propane. I have 2 space heaters and they supplement the heat pump very well. I have other projects to prevent fretting in the belly that I will do later.
Priusron is offline   Reply With Quote
furnace
