Old 01-20-2014, 08:16 PM   #1
Fresh Water Tank Dropped
I filled my tank to go to OK City because I knew it was going to be freezing. When I got there I could not get any water out of the tank. I noticed it was sagging 4 inches. I drained it and decided to tackle it the next day. When I opened it up I found this
ID:	45194   Click image for larger version
Priusron is offline   Reply With Quote
Old 01-20-2014, 08:27 PM   #2
Batts-toy's Avatar
Did the sag crimp your hose? I am not understanding how the sag kept you from getting water. How did you fix it and did the water flow come back? Sorry for your problem hope all works out.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 01-20-2014, 08:28 PM   #3
I was supported bu 2 12 in wide pieces of OSB plywood. It was sagging about 4 inches. A call to the factory confirmed that is was not the proper installation. They stated that they would send me a tank if needed. They are aware I am performing my own repairs under warranty. I do not want to move out of the rv to take it to the shop. Besides I can repair it to my standards. I cut a piece of 3/4 inch foil backed foam board to cover the bottom of the tank. I Then covered that with a piece of 1/2 inch plywood screwed to the metal frame a couple inched to either side of the tank. After re-installing the black cover, I installed 2 5 ft pieces of Unistrut as additional support. It turns out the pump was bad and I have now received the replacement. Dynamax is excellent about supplying replacement parts to include a new hydraulic cylinder. The plywood is visible in this photo on the left.
Old 01-20-2014, 08:31 PM   #4
Batts-toy, the design does not permit the hose to be crimped. That was my first thought. It turns out the diaphragms on the pump are bad and I have received a new pump. It will go in tomorrow.
Old 01-20-2014, 08:32 PM   #5
Batts-toy's Avatar
Good job, sounds like a good approach to the repair. I am like you I prefer to do my own work (fortunately no problems with my TT yet). Enjoy
Old 01-20-2014, 08:48 PM   #6
Here is the unistrut. It is used to attache pipes and cable holders to power poles. It is available at Home Depot.
Old 01-21-2014, 07:51 AM   #7
Batts-toy's Avatar
Thanks for the photo, his should keep the angles from spreading so they stay under the tank. I am familiar with Home Depot and the unistruts, I used some to build cross supports under my Wildwood T26TBSS when I switched types of stablizer jacks.
Old 01-21-2014, 10:23 AM   #8
I also added unitary under the front. I will go to electrical supply and purchase the hangers and hang some 5 inch pic pipe under for my sewer hose.
fresh water, tank, water, water tank
