Old 12-15-2013, 09:20 PM   #11
I have the same problem. Will try to insulate hole
Sent from my iPod touch using Tapatalk
Bob Schoug is offline   Reply With Quote
Old 12-15-2013, 11:39 PM   #12
Don't use spray foam. You may obstruct the heater duct. You also don't want to encase the water lines in foam in the event repair is needed. The best access is by remiving the lower drawer. Pull it out and you will see a little black tab sticking out from the innermoast rail. One side push up and the other down and pull drawer out.
Priusron is offline   Reply With Quote
Old 12-16-2013, 06:07 AM   #13
NELA
Weezer's Avatar
Reminds me of that huge hole in the floor that our sofa leg was falling in to.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 12-16-2013, 06:13 PM   #14
Thanks for the advice.I will let you know how I make out.
Old 12-26-2013, 05:58 PM   #15
No more heat.I put styrofoam around the hole and sealed it with reflectix tape.Thanks to all.
