Old 04-16-2014, 07:12 PM   #1
lgray's Avatar
In-Line Frame LP Tank Usage
We are trying for the first time to run the stove from the in-line LP tank. I disconnected the portable tank and flipped up the LP cut off tank switch inside the tank pull box. Unfortunately, we are not getting gas to the stove. What am I missing?
lgray is offline   Reply With Quote
Old 04-17-2014, 05:40 AM   #2
gauchoverde's Avatar
We have the two 40lb propane tanks. There have been a couple of posts related to your question. You might find them with a search.
Sent from my SPH-L720 using Forest River Forums mobile app
gauchoverde is offline   Reply With Quote
Old 04-17-2014, 08:41 AM   #3
lgray's Avatar
Thanks for the reply and yes, there have been a couple of posts that don't come up right away while searching. Evidently, there is a thumb screw on the big tank that was never turned on by my dealer.
Old 04-17-2014, 01:09 PM   #4
Sadly, you are not alone with the big tank issue. We all seem to find out the hard way. A handout or information from someone at the dealership would have helped me and probably everyone else.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 04-22-2014, 04:50 PM   #5
X 2 John. We found out the hard way too.
Sherry
WestWardHo is offline   Reply With Quote
Old 05-21-2014, 08:42 PM   #6
phil falls's Avatar
Mine still doesn't work but it worked fine last year. I have to check and see if my detector is working first and then we'll see. Hope for the best.
phil falls is offline   Reply With Quote
Old 06-09-2014, 02:17 AM   #7
phil falls's Avatar
I had tried everything I could think of but still not LP at stove or furance. Then just last week, I turned on the heat pump and it was working fine. During the night, we lost power so no moe heat pump. I just stayed under the covers until morning. When I got out of bed, I noticed that it felt worm. When I went down into the kitchen, to my surprise the gas furnace was working. I have no idea why.
Go figure.Click image for larger version
Name:	ImageUploadedByForest River Forums1402298212.931810.jpg
Old 06-18-2014, 08:46 PM   #8
air in the lines
Priusron is offline   Reply With Quote
frame, tank
