01-20-2014, 09:58 PM
Insulating the floor
When I opened up the belly, I discovered a remarkable absence of insulation. Up by the propane tank I add 2 pieces of r-13 insulation. Behind that I added 1 piece of r-13 on each side. This will not interfere with the mechanism for the slides. In the middle I added 2 pieces of r-30. That is 4 pieces sided by side. Each piece was 15 inches wide. The RV only gets down to 62 with the outside temp of 30 now. The floor is no longer cold. I was extremely satisfied. I also opened up the front belly but discovered the black and grey tanks are very well supported and i was only able to add 1 piece of insulation under a grey tank.
01-20-2014, 10:10 PM
imo, over time the batting insulation will get a lot of moisture on it and retain water, sag, the paper will disintegrate and you may have a mold problem. could you have tried to install some type of solid board type insulation?
Brother Les
01-20-2014, 10:16 PM
The furnace blows hot air into the belly through several holes in the duct. I can always open it up and remove the insulation. I hope with the flow of air through there it will carry off the moisture. I have read several forums and there was no good remedy that did not have negative consequences. 3/4 inch foam board with foil backing only has r-5 value. It would be difficult to get sheets into the middle area due to the ladder cross member. If I experience negative results, I will post them here.
01-20-2014, 10:23 PM
I was told that I have a 'heated underbelly' and when I when I pulled down the under board a little just saw the furnace duct tubes going the length of the TT. By your statement above, have you seen the 'holes in the ducts'? I assumed that it was just residual heat and not have actual holes in them.
Brother Les
01-21-2014, 08:15 AM
Yes there are actual holes in the duct to heat the underbelly. This is under the island and goes straight through the duct there is a smaller hole further back ad well. Look in your floor grill on the front side of the island. You may see some foil tape. It is holding your water lines in place. There has to also be a hole further forward to get the lines inside the duct. That makes 3 holes.
02-06-2014, 01:16 PM
I can confirm Ron's comments. There was NO insulation inside the under belly. Now I have my drain valves freezing closed. Argh! Told my dealer this is unacceptable and we are trying to formulate a plan for resolution. I like Ron's idea of installing the batting like you would a roof. Have a continuous piece the entire 38 foot length and the width of my 2008 Cedar Creek and had ZERO freezing issues.
More to follow...
John (S/N 409)
02-06-2014, 02:19 PM
I have never heard of wholes in your duct for heat in the underbelly, what TT do you have. Most units come with a 2" duct in the underbelly off the furnace. heated tanks and heated elbows take care of the other problem. There is some silver insulation on top of the underbelly which is about 1/4" thick with an
R value of 3.75. But can go up to R24. It is sold at HD and lowes in rolls mostly used to wrap water heaters but it is the same comes in widths up to 48".
It is sealed foiled front and back. Even if you have to double it you would never have a problem as Les brought up. Not cheap by any means. I will say this, if the factory cut wholes in my duct runs they would be replacing them.
Coachmen M/H
Concord
2018 / 300 DSC
02-06-2014, 05:59 PM
Priusron, please advise of any problems. I am curios why you did not fill up the space with insulation? Are the large gaps are counterproductive? Also I can not tell if the picture is right side up or upside down; Shouldn't the vapor barrier be on top towards the interior floor?
I'm totally ignorant on this issue, yet it seems so logical to do, and why isn't done at the factory with spray in insulating foam? This is pretty much the standard now for quality homes. Seems like that would be cheaper, easier and whole lot more efficient with no moisture and mold issue down the road. However, as I write I am thinking it may be a weight issue?
02-06-2014, 06:49 PM
Dave 01, the vapor barrier should be seen from looking in. The fiber glass should be against the floor. That is the correct way to install paper backed insulation. That insulation might not have vapor barrier on it. I can not tell from the picture either of how it was installed. The expandable insulation that is sprayed is really lighter and it even has a better R-value. that is why these units are called 3 season and not 4 seasons.
Coachmen M/H
Concord
2018 / 300 DSC
02-06-2014, 07:51 PM
I have a 3950 rl. There are holes in the duct to heat the belly. No vapor barrier in the insulation. If you spray foam any repair to wiring or plumbing is extremely difficult.
02-06-2014, 08:17 PM
I believe the furnace ducts are 4", not 2", at least mine are.
02-06-2014, 09:42 PM
Do you have holes in your ducts that allow hot air to flow in the belly cavity?
Brother Les
02-06-2014, 09:52 PM
Not that I know of but I've never dropped the underbelly to examine them. I just rely on the conduction & radiation from the thin aluminum flex ducts. Had several nights of mid 20 temps before we left Concord and just turned the furnace blower on with only the EdenPure electric heater going and the basement stayed in the upper 40's.
02-06-2014, 11:19 PM
The water supply line from the pump enters a hole into the duct. There are also additional holes for heated air. I have discussed this with John Armstrong and he confirms this is the purpose.
02-07-2014, 06:02 AM
I only have (1) 2" duct that is in my underbelly and that blows into the basement storage area. There is a 3/4 high wall that transfer the heat to the back that separates the storage area and the rest of the unit There is a short panel that I remove to access the valves that have to be switched to winterize behind that wall plus the water filter area, But I removed that and use a external high flow carbon one now. That is where I put the heater facing that area the blower on the heater pushes air across the pump and all the main lines. All my water lines start there except the fresh tank water line which go's to the rear where my tank is located. I get alot more heat pushed back to the rear that way. I have to watch out when I first started doing it that way I got the basement up to 80 degrees. I put (1) of my accuright remote temps down there from my refer to monitor the temps from the basement. I have only two (2") ducts that come off a 4" run with a y branch 1 go's to my bedroom right above the furnace and the 2 when go's to the basement right next to furnace. But it starts out as a 4" connected to the Plenum. This works for me. I will be putting in valves on my low point drains inside the basement since that is what froze on me the 6" exposed hanging down under the unit. When you shoot the pink stuff in for storage no problem, but when you are dewinterize using the unit there is really nothing you can do about it.
Coachmen M/H
Concord
2018 / 300 DSC
02-14-2014, 01:05 AM
I am still kicking around insulating the floor in the front storage bay or just putting in a ENVI passive heat wall mount panel heater, I installed one in the living area and have been testing it to see how it performs, and thus far it has maintained a 5 to 15 degree temp above the outside temperature (with no other heat source running) it only draws 450 watts and they claim it will handle 400 sq ft (yeah maybe in a sticks and bricks) and I have not used it with other heat sources as of yet to see how it performs. So at this point I really can't do much on the rig with 2ft of snow on the ground and daily below freezing weather , but I am thinking that instead of spending the time and money insulating that this Envi heater would more than do the job of heating the bay and keep the floors warmer......but like I said I am still up in the air on what I am going to do .
2021 Riverstone Legacy 39RKFB / 2021 Ford F350 6.7L DRW / 2021 Palomino 2910
