Old 08-21-2014, 09:24 PM   #21
You need to get your rv off the blocks. It is dangerous. Your system will lift the tire off the ground if needed and having it on blocks is unstable.
Priusron is offline   Reply With Quote
Old 08-23-2014, 04:07 PM   #22
lgray's Avatar
Agreed, replaced with cinder blocks, proper side up and solid 4 inch cinder on top.
lgray is offline   Reply With Quote
Old 08-23-2014, 08:13 PM   #23
Why do you need blocks at all? It is very stable on the jacks. it can not fall off the blocks. If extended for over a month, spray with silicone spray.
Old 08-23-2014, 09:03 PM   #24
lgray's Avatar
Less movement inside with less of the rams/jacks extended. There is a difference. We are pretty much seasonal. Less of the ram exposed to salt air is also a consideration. We are right on the ocean, corrosion is a big problem. I have re-painted and sprayed undercoating, underneath, in every place I found metal.
hydraulic, manual
