Old 05-29-2014, 04:17 PM   #1
Mods to 2013 36reT3
Name:	ImageUploadedByForest River Forums1401397507.884353.jpg
ID:	53701Click image for larger version
Name:	ImageUploadedByForest River Forums1401397542.005851.jpg
ID:	53702Click image for larger version
Name:	ImageUploadedByForest River Forums1401397558.679276.jpg
ID:	53703Click image for larger version
Name:	ImageUploadedByForest River Forums1401397573.117448.jpg
ID:	53704Click image for larger version
Name:	ImageUploadedByForest River Forums1401397594.041910.jpg
ID:	53705Click image for larger version
Name:	ImageUploadedByForest River Forums1401397612.351743.jpg
ID:	53706Click image for larger version
Name:	ImageUploadedByForest River Forums1401397634.716040.jpg
ID:	53707Click image for larger version
Name:	ImageUploadedByForest River Forums1401397653.295746.jpg
These are a few of the mods I have done so far. When I first got Rv I was curious to what all behind the walls in bay compartment so I took the panels down and discovered a small leak from hep valve and also had leak on mini block so after Dynamax sent me a new mini block for water cut offs I decided I wanted to keep better check for leaks so I decided to put a hinge door out of plexi glass on any compartment to make it easy to access and check for leaks. Also put a plexi glass over the mini block valve for visual inspection. Other addition was putting the two vents under the bay panel for better circulation to the underbelly. My next addition was purchasing the set of handrails that mount to side of steps main support. I done this because have small grandkids and two of them have already fell. Note I did have to do a little modification to the mounting bracket because door would hit handrail.
d69stang is offline   Reply With Quote
Old 06-02-2014, 10:42 PM   #2
Great mods.
Lawrence, JD and JJ
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 06-03-2014, 01:29 PM   #3
yes nice mod to visually inspect the innerworkings. I have also wondered how one should handle all the inspections that should be done often with those screw down panels in the cargo area. Does anyone know if the factory is still screwing those panels in or if the have some sort of slide or hatch access now.
TGAMO is offline   Reply With Quote
Old 06-08-2014, 08:00 PM   #4
gauchoverde's Avatar
As far as I recall from the factory tour, the panels are still screwed.
Sent from my SPH-L720 using Forest River Forums mobile app
gauchoverde is offline   Reply With Quote
2013, modifications
