Old 01-05-2016, 10:12 AM   #1
question
Does the 36RL have low point water drains? I found 1 drain line at the rear of the trailer - I'm guessing it's the fresh water tank drain. I also see a blue and a red pex line hanging down but no drain valve on them. What are these for? Thanks for any help.
Thumper7 is offline   Reply With Quote
Old 01-05-2016, 10:22 AM   #2
AquaMan's Avatar
Those (red & blue) are your low point drains. Most don't have valves on them, only caps that you remove.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-05-2016, 10:25 AM   #3
Mr. Dan's Avatar
... and if yours don't have caps on them, they have valves up inside the unit and out of sight. Let us know what you find.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 01-05-2016, 10:31 AM   #4
They don't have caps on them so there must be something above them
Old 01-05-2016, 11:30 AM   #5
lgray's Avatar
Our 2013 Trilogy has valves on the red and blue flex lines, outside the trailer. So you must have a valve inside, somewhere.
lgray is offline   Reply With Quote
Old 01-05-2016, 01:40 PM   #6
CC38EL's Avatar
The valves are located behind the panel covering the manifold on my 37 FB. That's how they are able to winterize it on our rig.
Jim
Currently without a rig
CC38EL is offline   Reply With Quote
Old 01-05-2016, 02:49 PM   #7
lgray's Avatar
If that is the case, that is unfortunate. With ours, we can drain everything, including the hot water tank from the external low point valves, after every use, without having to pull off the manifold cover each time. I guess an option would be to leave them open and add valves outside.
Old 01-05-2016, 03:24 PM   #8
I believe ours are behind the panel. I will take it off to check.
Old 01-05-2016, 04:06 PM   #9
Yep, they're behind the panel.
Old 01-05-2016, 04:30 PM   #10
CC38EL's Avatar
It is a pita, but the valves are protected, I guess.
Jim
