Old 08-30-2015, 01:16 PM   #1
CC38EL's Avatar
Rear tow hitch
This is probably somewhere already, but it escapes me.
Anyone know the limits on the 1.25" hitch on the back of the Trilogy? More specifically, the 37FB and the 3715FB.
I'm guessing 100 lbs hitch and 350 lbs weight....but it's just a guess.
Thanks.
Jim
Currently without a rig
CC38EL is offline   Reply With Quote
Old 08-30-2015, 02:16 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Yep, it's good for a bike rack, that's about it.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-30-2015, 02:52 PM   #3
That is a Class 1 hitch. No trailer light plug.
2015 Dynamax Trilogy 38RL, 2014 Ram 3500 DRW Maxtow package.
Kevinc2011 is offline   Reply With Quote
Old 08-30-2015, 07:15 PM   #4
I put the 1 1/4" to 2" adapter in mine, and then put our bike rack on. And then I promptly removed it. There is no way I am travelling like that. Too much slop and flex, I would not be comfortable having our bikes back there. Looking at how it is mounted, I think I am just going to cut it off and replace with a more sturdily built unit. Not interested in arriving at our destination, and wondering where we lost our bikes!
-lenny- is offline   Reply With Quote
Old 08-31-2015, 08:46 AM   #5
CC38EL's Avatar
Was the slop and flex in the 1.25" hitch piece or in the adapter inside the hitch you used to make it take a 2" insert?
Jim
Old 08-31-2015, 11:32 AM   #6
The slop is definitely all from the adapter piece. I just don't feel comfortable using that hitch, when I can easily upgrade it to something more sturdy.
Old 09-01-2015, 05:39 AM   #7
Have towed with 2 bikes on the smaller hitch for thousands of miles. My SWAGMAN rack is adjustable for either size hitch. YES, agree on the more sloppy situation when the adapter is used on my truck versus without it on the fifth wheel. I am a motorcyclist and have various ratchet straps at the ready. I always use 2 straps at strategic bounce points and it eliminates about 70% of movement. Nothing is perfect with the condition of America's roads!
Point to remember: regardless of type of rack; each trip when you remove bikes, keep the right tool(s) handy to check and tighten all bolts and nuts on the RACK ITSELF. They WILL work loose over time. ( trust me on this, don't ask how I learned this the hard way).
SilverbackMel is offline   Reply With Quote
Old 09-01-2015, 07:46 AM   #8
CC38EL's Avatar
Yes, it is a class 1 hitch, and I found a 250lb weight limit in a 2012 brochure.
Based on my observation of the frame underneath, which was nothing (means 'I can't see it without taking it apart'), and the lack of consistent data from Dynamax, I'm going to restrict my use to 225lbs (max minus 10%).
It probably could handle more, but in reality, it's all I need. Bikes and maybe some stuff I don't want inside the rig.
Here's the pdf I'm referencing: http://media.rvusa.com/library/trilogy.pdf
Jim
Old 09-01-2015, 04:22 PM   #9
I would be concerned about it bouncing in and breaking the back glass
Priusron is offline   Reply With Quote
Old 09-01-2015, 06:25 PM   #10
That is why I am hesitant to use it, they bounce around a lot!
hitch
