Old 03-14-2014, 10:21 AM   #1
Solar panels on a 3650RE?
I bought a 20W solar panel and would like to permanently install it on the roof of my 2013 Trilogy 3650RE. It will just be used to maintain the batteries while in storage. I would prefer to be able to somehow pull the wiring from the panel to the batteries with minimal effort, but I don't see how that can be done. What I'll likely do is just run the wire on the outside of the unit down to the battery bank, which would be unsightly, but functional.
I'm hoping that someone has worked on this exact unit, and can give me some pointers that I'm not seeing right now... Thanks in advance.
Scott
Arcosanti is offline   Reply With Quote
Old 03-14-2014, 10:34 AM   #2
Always Learning
I think that many people use the vent for the refrigerator to get wires from the roof down into the camper. Still tough from there to the batteries.
Old 03-14-2014, 10:52 AM   #3
Batts-toy's Avatar
Bring your wires through the the refrigerator vent as ependydad stated, mount your charge controller (either in the fridge compartment or drill a hole through the wood and bring the solar wires into the compartment below the fridge). If you are not using a disconnect to disconnect the batteries while in storage you can run wires from from the charge controller to the battery wires at the TT power converter, if you are using a disconnect find a spot where lines or wires go through the floor and run your wires from the charge controller next to them and through the hole and then along the frame to the batteries.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 03-14-2014, 11:14 AM   #4
KMP44's Avatar
Isn't the fridge in the slideout? That means no roof vent to run through.
I've read of a couple people going down through the plumbing vent. Not the easiest, but avoids drilling through the roof. I'm leaning toward running down the outside on my trailer and into the vertical channel of the awning. That would cover up most of the run down the side.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 03-14-2014, 11:20 AM   #5
Always Learning
It is:
I wish more manufacturers offered conduit that runs from the roof down.
Old 03-14-2014, 11:58 AM   #6
KMP44's Avatar
For sure - a piece of conduit, a cap, and some Dicor. Probably less than $10 in materials - call it a "solar prep package." Or go all out and mount a set of Z brackets on the roof as well. They sell for around $10 a set. Then anybody could install a decent solar setup without having to put any holes in the roof.
Old 03-14-2014, 12:21 PM   #7
Denver, CO
garbonz's Avatar
Forget the roof use a mobile panel. No holes anywhere and you can put it on a tripod, hang it from the ladder etc. Especially if it is in storage...
Name:	2014-03-13 12.16.21.jpg
ID:	47693   Click image for larger version
Name:	2014-03-13 12.14.52.jpg
ID:	47694   Click image for larger version
Name:	2014-03-13 12.15.42.jpg
2017 Fuse 23T
Old 03-16-2014, 10:51 AM   #8
Defiant530's Avatar
the plumbing vent is the route I plan to use when I add solar, no drilling into the roof , Punch a hole into vent pipe in utility bay, remove vent cap on roof and run a fish tape up the pipe, tape on wires and pull down length you need and be sure to leave a service coil in the bay (for any future changes) and seal the holes. Doing it this way seems to be the least invasive (and easiest ) way to go about it in my opinion
2021 Riverstone Legacy 39RKFB / 2021 Ford F350 6.7L DRW / 2021 Palomino 2910
Defiant530 is offline   Reply With Quote
Old 03-16-2014, 11:24 AM   #9
Denver, CO
garbonz's Avatar
Utility bay?
2017 Fuse 23T
Old 03-16-2014, 05:26 PM   #10
Defiant530's Avatar
Originally Posted by garbonz View Post
Utility bay?
ok I assumed people would know where I was talking about.....its the area behind the panels in your cargo bay ....furnace, hot water heater ,plumbing and electrical are all in there
Old 03-16-2014, 08:10 PM   #11
Denver, CO
garbonz's Avatar
Ahhh. I get it, the no man's land of mysterious wires and tubes and pipes behind the cargo space. Very good idea.
2017 Fuse 23T
Old 03-16-2014, 10:04 PM   #12
gauchoverde's Avatar
Could you piggyback at the place the JACK TV cable goes through the roof?
Sent from my SPH-L720 using Forest River Forums mobile app
gauchoverde is offline   Reply With Quote
Old 03-16-2014, 11:06 PM   #13
Defiant530's Avatar
Yes that is the area where the magic happens ......lol. gauchoverde your Idea is also possible to use but I am not a big fan of punching a bigger hole in the roof due to leak possibilities, I see the vent pipe as one big conduit and don't forget the connectors on the cables are another thing to consider . the cables could be cut to fit but I myself prefer not to do it due to the splice point being a point of failure (corrosion or splice failure)
365, solar
