Old 04-28-2015, 11:47 PM   #1
Working the Life
KD Nolte's Avatar
Unhappy Suburban Furnace_Failure
Trilogy 3800D3 Unit #92
This has been a really lousy week. First my Microwave / Convection Oven craters, now the Furnace has cratered.
Has any one else had their furnace fail? When I turn the Thermostat on I hear a click in furnace but that is all that happens. I have powered down the circuit and re-energized the circuit with no difference. I have confirmed that the thermostat works as it controls the Heat Pump.
Any suggestions?
2013 Dynamax Trilogy 3800D3 (Feb 2013)
2014 Sierra Denali 3500 DRW
KD Nolte is offline   Reply With Quote
Old 04-29-2015, 08:44 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Could it be that for some reason the solenoid on the propane tank is closed or not opening properly, or the furnace itself is not getting electricity (tripped breaker)? Sorry, I'm just poking around. At least it's not freezing cold anymore.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 04-29-2015, 08:54 AM   #3
mcnabbwr's Avatar
Does your stove top work? If it does that pretty much rules out a gas issue. Just guessing but make sure your thermostat switch is set to heat, also check the fuse. Hope you get it figured out.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is online now   Reply With Quote
Old 04-29-2015, 08:57 AM   #4
lgray's Avatar
If it is an issue of no propane, don't forget about the thumb screw brass valve, dime size, on the large tank.
lgray is offline   Reply With Quote
Old 04-29-2015, 08:57 AM   #5
TURBS's Avatar
He said it just clicks.
So the blower fan isn't even running.
Checked fuses?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-29-2015, 08:58 AM   #6
Working the Life
KD Nolte's Avatar
I verified that the propane system works by using the stove burner. Have reset the breaker and hear a click on the furnace when the thermostat engages.
I wish it wasn't cold anymore. I'm in Northern BC and the night temps are in the low to mid 30's F.
Thanks for your suggestions.
Old 04-29-2015, 09:02 AM   #7
TURBS's Avatar
Did you check fuses?
Your furnace is 12 volt so there is no breaker.
TURBS
Old 04-29-2015, 03:42 PM   #8
fonzie's Avatar
I've had same issue, read post #7
Furnace won't light!
Fonzie
Old 05-09-2015, 07:09 PM   #9
Working the Life
KD Nolte's Avatar
RV Tech came to site and Solved issue
The issue with the Furnace was the Circuit Board.
The RV Tech finally came out to repair the furnace and found the Circuit Board was the issue. Boe's RV Service in Dawson Creek, BC have been great to deal with. They were willing to deal with the Extended Warranty company and are working on the Frigidaire Micro Wave Convection Oven.
Thanks for all your Helpful Hints.
KD
Old 05-09-2015, 07:24 PM   #10
Interesting that you appear to have had two electrical failures at the same time. Did you have a power surge, perhaps?
I would have expected the converter to fry before anything using 12VDC, but who knows?
2011 Traverse LT, 3.6L, FWD
furnace, suburban
