Old 06-30-2015, 08:29 AM   #1
gauchoverde's Avatar
Suspension issues.
I know several have installed mor/ride disc Brake systems. How are they working out?
I have had several issues with original alko axles. One brake backplate replaced. Axles replaced due to camber issue (tire wear). Still wearing tires. The latest is the rear hanger on the curb side failed.
ID:	81709   Click image for larger version
ID:	81710   Click image for larger version
gauchoverde is offline   Reply With Quote
Old 06-30-2015, 10:10 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I don't know what model yours is, the axles on ours are bolted on - not welded and I am no fan of leaf springs (not saying they are bad, but on a trailer like the Trilogy - no).
We have 8000# axles with independent suspension and disc brakes and love them. If you decide to upgrade this is the setup I can recommend from personal experience with the addition of shock absorbers. Remember, road shocks should be absorbed before they travel to the trailer frame to reduce bounce and that's where leaf springs are not the best option. They need regular lubrication but that's about it.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 06-30-2015, 10:29 AM   #3
Ours is a 2014 36re. What model do you have and did it come that way or did you get it upgraded?
Old 06-30-2015, 10:33 AM   #4
mcnabbwr's Avatar
There doesn't seem to be much consistency, my axles are Lippert and the brackets are also welded to the frame.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 06-30-2015, 10:39 AM   #5
We have a 2014 3650 RL (see signature) custom built. I'm not at the trailer right now, but I could try to sneak out this pm and take a couple pics. of our setup.
Ordered: 2021....
Old 06-30-2015, 12:50 PM   #6
Both lippert and alko axles we're used with the tru-trac leaf spring system with welded hangers
Old 07-04-2015, 01:23 PM   #7
The Lippert/Alko system failed on my coach this past April. I too am looking at upgrading to the Mor-Ryde system, with shocks.
retamaman is offline   Reply With Quote
Old 07-13-2015, 05:09 PM   #8
I had MOR/ryde IS and Disc brakes on my 2008 Cedar creek and ordered my Trilogy with the MOR/ryde IS and Disc brakes as well. No issues in over 12,000 miles since purchasing the Trilogy. Would NEVER own a 5th wheel without the MOR/ryde systems.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 10-06-2015, 07:22 PM   #9
When we arrived in Whistler, BC. 800 miles from home...
Luckily I was able to talk the CG management into letting me get a welder onsite. I could understand their concerns, with noise and smoke for the other campers, but I was able to time it after checkout and before check in to minimize the number of people affected. Was only one other couple there at the time, and I went over and explained the situation to them. They understood.
Finished product:
Interesting that ours was the right rear as well. This was not new, as 2/3 of the break was well rusted. I looked at all the other hangers and there was no cracking evident.
Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 10-06-2015, 07:40 PM   #10
Originally Posted by -lenny- View Post
...Finished product:...Interesting that ours was the right rear as well. This was not new, as 2/3 of the break was well rusted. I looked at all the other hangers and there was no cracking evident.
IMO, from a design engr standpoint, I would have boxed all the uprights (4 total) to spread the load, leaving just enough room for the swiveling of the spring shackles. Boxed similar to the center ones. The fronts could be boxed the full length on the front and only part way on the back of the fronts.
Old 10-06-2015, 07:49 PM   #11
trbomax's Avatar
I was thinking the same thing,but really did not want to critisize someone elses work,but since you said it first............X2^^^
trbomax is offline   Reply With Quote
Old 10-06-2015, 08:06 PM   #12
Lol I don't think Mor/Ryde will have hurt feelings. As for my welder, I was just trying to get mobile again.
Trilogy 38RE
Old 10-06-2015, 08:16 PM   #13
trbomax's Avatar
understood!
Old 10-06-2015, 08:21 PM   #14
The design obviously does leave a lot to be desired though. Im sure boxing it would help, but not sure if that would solve it. Maybe a suspension upgrade is in order?
Trilogy 38RE
Old 10-06-2015, 09:20 PM   #15
I believe there should be a recall! !!
Old 10-07-2015, 09:43 AM   #16
Im certainly no engineer, but I was thinking, too, that the point where the support is welded to the frame looks like it's 2-3" long at most, and should be more like 4-5" to better spread the load. I'm going out to check mine today.
phillyg is offline   Reply With Quote
Old 10-07-2015, 09:48 AM   #17
The spring hangers are subjected to tremendous side loads when the trailer is turned and boxing the hangers will eliminate the side load.
Old 10-07-2015, 11:01 AM   #18
I had a length of square tubing welded between the two carrier brackets. The curbside bracket was folding in.
Old 10-07-2015, 11:02 AM   #19
The lip of the I beam was distorted.
suspension
