Old 03-28-2015, 08:54 PM   #21
lgray's Avatar
[QUOTE=Studmuffin;819393]KW1 WATER FILTER $28.99 DELIVERED!
After reading all the threads regarding the KW1 filter and where to buy and where not to buy.... I found the filter for $28.99 and that included shipping! The company is called Hanna Trailer Supply and their web address: hannarv.com and the link is for the KW1 filter is: The Water Pur Company KW1 10-inch Water Filter - New Forest River RV Water Filter | Hanna Trailer Supply Oak Creek, Wisconsin
I hope this helps some other camper enjoy saving a few dollars that can be spent on a camping trip!!
You are still paying $28.99 for each filter. Or replace the entire system for about that price and every filter thereafter costs you only $3.00 to $7.00, with improved gallons per minute going from 2.5 with the KW1 to as high as 4.5 with Pentek or GE...much better showers!
Pentek 1/2 inch casing: https://www.filtersfast.com/Pentek-1...er-Housing.asp $16.78 Replaced my FR1/KW1 in my fifth wheel add $5.95 for better bracket and $3.00 for filter...15 minute install.
lgray is offline   Reply With Quote
Old 03-30-2015, 12:18 PM   #22
I changed out my FR default filter system as well. Good thing as I have been changing the filter about once per month. Some of the campgrounds have nasty water, even just for showering! I couldn't afford the FR ones at that price...
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 04-13-2015, 03:23 PM   #23
nosaint3
I kept the KW1 original filter in from Sept 2013 to April 2015 at which time I had no pressure in my trilogy for anything. I took out the filter and just replaced the housing and got great pressure. I ordered two filters but haven't installed one yet. I have a whole house filter and water softner outside for now. I'll check the KW1 pressure after I install it. My outside filter and hose were loaded with green algea and water. The KW1 caught most of it but did clog up.
nosaint3 is offline   Reply With Quote
Old 04-13-2015, 03:26 PM   #24
Originally Posted by nosaint3 View Post
... The KW1 caught most of it but did clog up.
That is to be expected.
Old 04-13-2015, 03:49 PM   #25
5er_tom's Avatar
I posted earlier in another thread that the FR1 filters were being sold at the Goshen rally. They were about $20.00 for three!
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 04-14-2015, 09:49 AM   #26
mud yapster's Avatar
Thanks for the info I just ordered a Pentek 158649 which I ordered 4 replacement filters with it and it was still cheeper than ordering 1 KW1 filter cartridge. Got the Filter canister and 4 filters for $41 with shipping. Thanks again
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 04-20-2015, 10:27 AM   #27
nosaint3
I just installed a new KW 1 filter as posted above and I just discovered at 0230 this morning that the canister fell off. Lots of water dripping/pouring out of my storage area. I shut off the water, re-installed canister, and operated pump the rest of the night. Made sure it was to tight to fall again at daylight and made plans to buy a new filter system when I use my last filter.
Old 04-20-2015, 10:43 AM   #28
Ouch sorry to hear that.Hope it didn't cause you any water damage. I'm still waiting on my new Pentek canister and filters to show up.
Old 04-20-2015, 03:52 PM   #29
Can you use all the 10" filters with the Pentek filter? all the GE etc etc?
Ron
asparky is offline   Reply With Quote
Old 04-20-2015, 04:56 PM   #30
lgray's Avatar
Ron
Yes, all standard 10 inch filters.
Remember, the KW1, is nothing more than a low quality normal 10 inch filter with a nipple added to keep you from being able to use a better, less expensive replacement.
I have two Pentek's, one in my Trilogy fiver and portable set up for my Class C. Over 1 year and never an issue, with much better water pressure than the F1/KW1 set up.
water, water filter
