Old 10-08-2015, 10:57 AM   #41
lgray's Avatar
Originally Posted by gauchoverde View Post
I am using a two filterombo from RVWaterfilterstore.com I am very happy with it.
I think the OP is asking what type of filters do you have in the system?
lgray is offline   Reply With Quote
Old 10-08-2015, 11:07 AM   #42
gauchoverde's Avatar
Ok the sediment filter is 5 micron and the second one is a carbon filter
gauchoverde is offline   Reply With Quote
Old 10-08-2015, 11:17 AM   #43
mcnabbwr's Avatar
Same here. One carbon and the other is a one micron sediment.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-08-2015, 05:20 PM   #44
Thanks for the quick replies. Since my space is confined, I am limited to the single canister option. Based on @lgray's response, I think I will go for the combination sediment/carbon filters. Most of my water usage is via the fresh water tank (no direct connection hookups at the campsites we frequent), and we do bring a separate container for drinking water. My main focus was to avoid forking out the $40 every season for a new filter. The smaller micron filtering and gpm improvements are bonus.
In case anybody wants to comment on usage experience, this is the filter that I'm planning on trying first:
https://www.filtersfast.com/P-Pentek...ter-Filter.asp
Thanks!
kwsutter is offline   Reply With Quote
Old 10-19-2015, 02:55 PM   #45
Soooooooooo, the Waterpur website doesn't even mention a micron filter level for their products, but we're supposed to believe it's a 5 micron filter because their salesman says so? I call BS on that one. Much like the supposed FR "quality control" program; it looks like smoke and mirrors to me. I'm converting to a reputable name brand willing to stand behind their products with hard facts.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
danking49 is offline   Reply With Quote
Old 10-20-2015, 07:17 AM   #46
lgray's Avatar
When I called, I was told 30 Micron. With that Micron level, you would think their filter would provide better water flow, not so just the opposite.
Old 01-17-2017, 06:40 AM   #47
Green horn
Stebbie's Avatar
Rsl
Was looking at the same company for my full rv system. I was going to go with the standard vs jumbo. Were you informed of a possible flow issue using the standard? That's my major concern at this point. Thank you for any input you can offer.
Stebbie is offline   Reply With Quote
Old 01-28-2017, 02:26 PM   #48
dmchapman's Avatar
Well, I'm convinced. I was about to order the KW1 filter from the supply company that ships for free then got to thinking about the many reports of the FR1 leaking or outright breaking. Ours has been in use since July 2015 without a problem but I decided to change to the Pentek 15862 housing and a 2 pack of DuPont WFPFC 8002 polyester/carbon cartridge. About $38 delivered. Got to do some kind of mod during the Winter downtime.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 06-19-2017, 09:29 AM   #49
I read that there is a tit on the KW1 unit that prevents other filters from being used. Is it on the filter or the housing and can it be removed?
2014 Georgetown
2005 Goldwing
2014 Jeep Wrangler
retired Army combat vet
Greydragon is offline   Reply With Quote
Old 06-19-2017, 09:44 AM   #50
RandK-M's Avatar
It's on the filter cartridge and fits into a recess in the filter housing. Basically, with the stock housing, you're stuck using the expensive cartridge.
The options as I see it are:
1. Use the expensive cartridge.
2. leave the filter housing empty and use an outside filter or nothing at all.
3. Change the filter housing to a standard brand like Pentek and use whatever less expensive cartridge you like.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
water, water filter
