We are full time. 2014 Trilogy 3850RL serial number 409. Spend most of the summer in Oklahoma with 95+ degree days for weeks on end. All three ACs run about 18 hours per day, but do cycle. We leave them set around 74.
I have had a total of four (4)
failures so far. One on each of the units and a second failure on the middle unit. I have one spare plastic and one spare metal blower wheel available. The next one to fail gets replaced with the metal one.
I have seen on other forums folks are having same issue.
No rhyme or reason that I can figure as to why they fail. Mike Dickey from AirXcel says it is because the AC units are tightened down too tight, they bind and then fail. I don't agree. I measured my clearance on all three factory installed ACs and they are within Mike's specs.
Cheap plastic trying to fill the job of metal.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
